Part # For correct 02 Sensor?
WILL SHO U
Sooner or later
Home of the Indy 500
Is this the right 02 Sensor for a 94 3.2 Atx?
BOSCH Part # 15716 {Oxygen Sensor - OE Type Before Catalyst}
Two required; Can use sensor with longer wire harness Interval=100000
Found at rockauto.
Storm-Chaser
Shit Louis
Here's the OEM part number....
Personally, I wouldn't use anything Bosch in my cars.
The Ford part number is FOSZ-9F472-A, and it;s one of the few parts that Ford hasn't discontinued, due to the broad number of applications.
RAYJAY
WHO ME ?
UNION DALE PA
I have the bosch in both carsI have and no problems my 1994 has 13,000 + on the O2 sensors
only difference on a front and rear is the length of the wire .....front one is shorter
Jeff
Storm-Chaser
Shit Louis
Sorry,
Here are the oxygen sensor part numbers for both the ATX and MTX:
ATX / F1SZ-9F472-A
MTX / FOSZ-9F472-A
My understanding is that the difference between the front and rear sensors is the length of the wire-harness lead, and the above sensor numbers will work in either position. In the MTX there was no "down-stream" sensor. And if I remember correctly, Denso was the OEM supplier for the sensors. email me and I can hook you up with a source if you want OEM.
WILL SHO U said:
Rockauto lists a "front" sensor, i know theres a rear, is there a difference? Also is the ATX version?
RAYJAY
WHO ME ?
UNION DALE PA
Sorry,
ATX / F1SZ-9F472-A
MTX / FOSZ-9F472-A
there is no down stream in the 93 to 95 ATX either........the down stream came with OBD II
the motorcraft numbers are DY 606 =MTX
DY 649 = ATX
motorcraft would be the same quality as a factory part.
I think rockauto is $55 bucks for either sensor
projectSHO89
SHOless In St L
St. Louis, MO
The Bosch sensors have proven themselves to be completely reliable and effective in these cars. There is no valid reason for not using them.
All OBD1 vehicles only have "front" sensors. "Front" does not equate to their position relative to the engine placement en the car, but to the position relative to the catalytic converter. OBDII (1996-on) vehicles have one or more "rear" O2 sensors that are there to monitor converter performance. The terms "front" and "rear" are used interchangeably with "upstream" and "downstream".
Steve
RAYJAY
WHO ME ?
UNION DALE PA
thank you steve, when i say front and rear what i mean is
front = o2 sensor is rad side (short wire )
rear = o2 sensor is fire wall side (long wire )
thats the way our advanced auto store ask when you buy a sensor there ..
Jeff
crystizel
