keny_kimmel
ETSN Kimmel(SS)
I'll be as informative as possible so I can get help ASAP.
The solenoid had burned out, then even after I replaced that solendoid the cables were a little loose, the ones from the battery. Sometimes it would stutter when starting or not start at all untill you tried it 2 or 3 times all you got was an audible click. NOW, I replaced the cables and still had the old solenoid in and this time I noticed that the cables got loose again. This was after the car would refuse to start and I would hit the solenoid with a hammer. Well tonight I had to have the car towed.
There is a slight audible click when you go to crank it but the car doesnt even attempt to start. Could I have burned it out from the loose connection and repeated beatings with a hammer?
I need help ASAP I work at 2pm PST and have to walk to the part store tomorrow at 8 when they open.
