platoribs
Live to Drive
Video Rawx
and remember this rule: it's your job to cheat and it's the tech inspectors job to catch you.
asphalt is for driving to the track dirt is for racing!
don't go with the large brake set-up it will not be worth the added rotating weight for the benefit you will get.
i gust went to measure my cobra calapers to see if they could be fitted to your stock 10.5" brakes and they can't be. you can get them on 11.6's but your not making enough power to need the larger rotor. I believe the mustang GT (NOT cobra) duel piston calaper will bolt up to the SHO. i'm not sure if they are alum like the cobra's though. the cobra calapers are about half the weight of the factory calaper. I wonder if you could use the GT bracket with the cobra calaper so that you get the bigger pistons.
Not necessarily...that may be too much bar depending on what's on the front and how the rest of the car is set up. Going from zero bar to 26mm is going to be, well, exciting.
lift just enough to rotate it in, then stand on it again. Corner grip will be most excellent with the no front bar/big rear bar combo. you can't hardly spin out a nose heavy SHO, short of just dumping the throttle hard mid corner. it'll wag, but it's hard to get one to come all the way around.Yea baby.. that's what I'm talkin about right there. Its nearly impossible to loop a FWD car on a banked track.. if the back end starts to come around, just stand on the gas and pull the ass back in. A push is death in FWD circle track.. you can't get into the corner, can't hold your line through the corner, can't get on gas... it just sucks, I'd take 10x loose over 1x tight anyday of the week. Remember were talking about cars here not.. nevermindyeah dog!
drive it like a sprinterlift just enough to rotate it in, then stand on it again. Corner grip will be most excellent with the no front bar/big rear bar combo. you can't hardly spin out a nose heavy SHO, short of just dumping the throttle hard mid corner. it'll wag, but it's hard to get one to come all the way around.
yeah dog!
If indeed your just way to loose getting into the corner, I'd still stick with no front bar, and size down the rear.
Just 4 more days.. I'm going to run it Friday Night at the 1/4 track and Saturday Night at the 3/8th mile.. i hope to come back with 4 checkered flags !!That video is so sweet! I love how you run away from that New Yorker in each straight. I can't wait to see another video once you get a rear sway bar.
I didn't say you couldn't loop it on the road track.. basically flat and going left and right.. but on a circle track.. it'd be really tough.I spun my SHO at Thunderhill (at the '04 SHO con), but I had sticky race rubber on my front tires, with street tires on the back, and I was braking in the turn. :-D
