Clutch burned out in <3K miles ????
Dan Gillespie
Park Ridge IL
92 MTX with 105K miles. Bought at 102K miles Ford installed Clutch with 40K miles when right away. Suburban Transmission did work new TOB, PP and disk. 6500 mile warranty. After 1200 miles started to slip so bad took back and they replaced (I hope) the disk etc. Now at about 1800 miles same story. Checked cable ajustment and movement everything looks good. Read up on clutches and see that these cars are clutch eaters if the right parts are not used or put in wrong. Some heavy driving but no drag strip every day. Any ideas on why this is happening? Shop will not repair again, nor do I want them to!
JoesSHO
Reality
Clutch problems are so difficult to figure out without a parts list of what they used, and probably pics of everything. Also, they are easy to dump that fast if the car isn't being properly driven. Not accusing anyone of anything, but it only takes a few bad habits to **** a clutch fast... More details on what they used for parts/kit are in order to make a good reccomendation.
Sexymeatball
MA
Hopefully the rev. B TOB was installed with the clutch. In this revision, the TOB rides on a metal sleeve that slips over the input shaft of the transmission. This sleeve must be spiked to the input shaft or it can cause problems. It happened to me and manifested as increasing difficulty in shifting that eventually became impossible. I did my second clutch job after less than 5000 miles and made sure to spike the sleeve on this time. Shifts great now.
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
if they didnt do it right ie. not fully seat the PP to the flywheel... you can have problems like this... when the clutch wears down... the pp will no longer engage or fully engage with the clutch...
get a good kit, and do it yourself... there are probably a few sho owners in your area that would be more than willing to help out for a six-pack
1993MTXSHO
Its a Taurus...
Jersey
just a thought but have you broken in the clutch each time? because not breaking in the clutch can significantly hurt the clutch life and make it slip at a very early age. Im pretty sure thats all clutches but it could be more race clutches then oem replacement.
Cocoa,Florida
agreed, a proper break in period of 400-500 miles
needs to be observed anytime a new cluthc is installed,was this done?
Dan Gillespie
Park Ridge IL
Thank you all for the replys. I have finished reading some of the other threads and it seems like there are many things that can go wrong. In regard to the break-in period, is there a specific guide on exactly what should be done during the break in period? This was the first time in my life I had a car with a brand new clutch.
doclees
Harrisburg pa
You should get your money back if they don't want to do the work. If you like to throw away money throw some my way. I'll send you a thank you card.
warmonger
earth
^^^hahahha
proper brake in means no wide open throttle runs..no nailing the gas abruptly...just regular old granny driving
1993MTXSHO
Its a Taurus...
Jersey
warmonger said:
^^^hahahha
yeah jsut go easy on it for 500 CITY miles if your driving all highway that not using the clutch at all so make it more like 2-3k highway miles, or am i off on this on guys? My spec stage 2 clutch said 500 city miles so im just guess what id be highway.
warmonger
earth
i never looked at it that way,but that makes sense......hmm so if thats true,my clutch needs more brake in time.....
Endri_SHO
SE 300 , S 500
IN THE MERCEDES-WORLD
yeah that too but also if theyd ont give you the money, sue them and see what happens.. ya know..:thumb:
Storm-Chaser
Shit Louis
Yeah, well that's what one would think . . . . Looking for a garage . . . .
