1989 ford tuarus sho to 280zx swap
Dense0cactus
Texas
Hello so im still doing the seap its been a minute since ive posted here about the car. Now i have a question if i am planning on not using the powersteering or the ac where can i mount up some motor mounts, will the holes to mount those brackets be able to be used fab up dome motor mounts to that area?
Irish Pride
Irish Inside
MusicCityUSA
Most people not using AC will gut the compressor and just use the shell. You cannot mount the alternator without the AC compressor. The outer alternator bracket attaches to the compressor. I've seen it posted that the compressor is vital to the motor mount bracket as well. It adds rigidity to the bracket. I don't know if that is true or not but you would need to find a solution to the alternator first to proceed.
-Chad
Dense0cactus
Texas
-Chad
Well that sucks well any other ideas? To use the oem motor mount? The engine bay looks like this with the engine in it10000577291000061479
black92
Wisconsin
The AC compressor is indeed a support for the motor mount and alternator in a stock application.
In your case, you can remove the compressor if you can design and engineer a motor mount to effectively support the motor. It has been done several times.
Dense0cactus
Texas
So i can take the the compressor off and use the holes to make up a motor mount
12KSHO
