2010 Head unit Sony and Nav upgrade options
ForcedAccountsBad
Kansas
Pretty sure I know the answer to this question as I have been searching for some time now and haven't found anything but I figured I should see if anyone else has done it before I throw the towel in;
I have a 2010 with the Sony sound system and navigation and have been searching through not only this forum but just about all the corners of the internet for a head unit upgrade and cannot seem to find anything that will for sure work, the closest I found was from Navtool after I saw another user install theirs: https://shoforum.com/threads/so-what-did-you-do-to-your-sho-today.130526/post-1614172 and I think that's my best shot to get modern features, but that's more of a work around and at their asking price I would rather have a full upgrade ($600 at the time of writing).
There are a few units on Amazon/eBay/random online stores that claim to work but I have not seen anyone install them, and they don't seem very reputable.
Is there a replacement option for this car that anyone has done? Or is it a lost cause like I suspect it is?
I am an Amazon installer and yes mine had a defect that slowly drained the battery, and fortunately my Amazon seller replaced mine with the 2017 recall of the F150 models and the second worked. but doing the job twice was a pita. here are some links and possible help.
my guy from amazon, still around and did provide me a swap out for the parasatic draw my first one from him did. I would suggest using him if all else fails: https://a.co/d/02BiCJjO
another vendor you can call : https://naviupgrade.com/guides/
ForcedAccountsBad
Kansas
So as far as I can gather that will work on units with the Sync 2 for sure, (so models 2013+) but in cases like mine where I have the pre-facelift I have been unable to find anything, granted, I haven't tried plugging in a Sync 2/3 but I have seen others ask about upgrading the unit I have to Sync 2/3 and found they were incompatible, something about the earlier units being Windows and the later units being Blackberry https://www.taurusclub.com/threads/...3/?post_id=3487057&nested_view=1#post-3487057.
Now, in all fairness, I haven't seen anyone else try either so its possible that it would still work but that's what I could find.
This is the type of unit I have
2010 taurus sony nav
Majestic
ForcedAccountsBad
Kansas
The only concern with that one is the reference image they use shows a standard non-Sony non-Nav unit but I'll contact them and see what they say, given the age of their unit I'd be surprised if anyone responds
yeah sorry I keep forgetting about the earlier models and you are most likely correct in not finding many options.
try looking up iDatalink Maestro RR
or
Brands like Awesafe, Topdisplay, and various "Tesla-style" vertical screen manufacturers dominate this space.
How they work: These units replace your entire factory radio bezel with a large 9-inch or 10.1-inch glass touchscreen. They come with a custom, plug-and-play wiring harness that plugs directly into your factory Ford connectors.
Jensen JC7DM 7" Touchscreen Monitor
Florida
Sync 2/3 upgrade is out of the question for you unless you plan to swap in a lot of other stuff from the 13+ cars. my understanding is the IC communicates directly with the infotainment system. sync 1/2 are microsoft built but not compatible with each other, sync 3-4 is blackberry (I think, I know they stepped away from microsoft for sync 3). as for viable options for your car @Joshw0000 posted this about Navtool https://shoforum.com/threads/so-what-did-you-do-to-your-sho-today.130526/post-1615629 and it may have been him I talked to about the non existent install plate to get a regular double din head unit in the hole but I cant remember exactly and it was somewhat of a dead end. 10-12 cars have it rough (but at least your car says things like "good morning" thats cool, its the little things for me)
The radio anatomy is as follows: Touch screen, APIM (attached to screen, primary interface/navigation), ACM (under screen, CD player/receiver, primary audio processor), Amplifier/DSP (Trunk mounted behind drivers side wheel well, sony system only Digital sound processor) The APIM handles your GPS and the audio processor in the trunk handles signals from the ACM.
If you were to remove the ACM/APIM and replace them with a plug and play unit, they would have to provide a stand alone gps antenna (most do) or have a way of using the cars integrated antenna that is part of the main harness which model specific aftermarket interfaces will likely have the correct plug for the car prewired to address any systems being replaced. Thus taking care of the navigation concerns, plus many of the aftermarket radios rely on connected devices to provide a GPS location.
since an aftermarket system also replaces the ACM the new unit would have to provide the same level signal to the DSP which should be an option in the audio menu of the aftermarket radio as the factory ACM can also be changed to output for either Sony DSP or standard audio. It would appear that if you had the navigation 8" screen you automatically had the Sony system. Based on what I am seeing, the 8" screen was only offered with navigation and to my knowledge the Sony system was only offered with an 8" screen. So because there is so limited information about this particular issue, deductive reasoning would suggest that if you have as screen, you have sony/nav, which means the China listings that neglect to mention if it is specifically Sony but show a screen with the buttons across the top like the 10-12 cars are for your set up. Its a gamble but still an educated guess as to if it will work or not.
Screenshot 2026 05 29 115258
**** like this is confusing and ridiculous, note it shows it will work for a 12-18 car, however the year range is 13-19 for the style depicted in the lower pictures with 2 VERY different head units that do not interchange with each other. However, the top photo with the actual unit installed shows a 10-12 dashboard based on the gear shift, steering wheel, buttons, and gauges. Things like these, stay away
Screenshot 2026 05 29 115633
However, listings like this, which not only have the correct year range listed but depict the correct car interior are a safer bet. this is a picture from the listing showing the left (10-12) being the correct original dash for the unit for sale, and the right (13-19) being not compatible. notice how neither has the sony badge either on the left on the speaker cover or the right above the volume ****. copyright is a ***** but as I said above, based on the available options for the 10-12 cars, screen = sony/nav which means this is the correct chinese aftermarket option for the 10-12 SHO. the link for the good listing is below:
The full upgrade comes with a far superior screen, more modern functionality, and you avoid the inevitable sync 1 crash that there is zero support for. Unfortunately there is not an inexpensive option to upgrade or fix the 10-12 systems, you have a narrow aftermarket replacement selection, and adapters to make your current system a little better. I cant attest to the longevity or build quality of the aftermarket unit, But I would chose to replace the entire thing given the cost being so close. Good luck
ForcedAccountsBad
Kansas
In that same thread @PabloHoney managed to get something installed but I don't know how usable it was as they never followed up on it https://shoforum.com/threads/so-what-did-you-do-to-your-sho-today.130526/post-1588830
I think its just gonna be a shot in the dark like you said, worst comes to worst I have to return and reinstall the old unit if an eBay android one doesn't end up working... But I've yet to see any surefire solutions which is really the reason I haven't jumped the gun on any of these Android units. There's no guarantee any of them will even be compatible from what I have gathered. I'll update this thread if I do end up getting one and post about any findings I make on it, I would really like to do this but I'd also like to only have to do it once lmao
Majestic
Having just replaced my control panel I can tell you that it's not that difficult, just a lot of trim panels to remove.
ForcedAccountsBad
Kansas
I believe it, I've watched a couple videos of other guys doing it, not that there are many but some had the screen and some were without the screen, the general consensus is that its not necessarily hard to do its just tedious and requires some patience. Is yours also a 2010-2012?
Majestic
No. I have a 2013.
Majestic
Lucky, I would've just thrown in a Sync 3 upgrade if I had a 2013+ instead of browsing these Android units lol
I considered it but couldn't justify $600 for something that I rarely use. My phone handles navigation and music just fine. I replaced the panel because the climate control had a mind of its own and THAT was close to $400. I just don't like dropping big bucks on a car that might be worth $10k.
ForcedAccountsBad
Kansas
That's fair, frankly if mine wasn't being temperamental I'd probably be happy with it but the map being as out of date as it is and the fact that it doesn't like to stay connected via Bluetooth... Its not high on my priority list but I figured if an option existed I'd at least consider it, problem was/is that I still don't know if any of the available options will even work
Florida
I have a sync 3 set up programmed to my taurus so it should work in any of them ill let go. all but brackets and ACM but stock acm will work anyway.
As for the android units, theyre all pretty much the same. Ive had 4-5 all the same interface, not for the taurus of course but the general set up i imagine is the same. I bought one of these full integration units for my wifes fusion and the unit worked fine, very similar to the one in the link and it was plug and play, it was the audio tuning I couldnt live with and my wife HATED not having a regular volume wheel so I yanked it back out. From my experience with these style set ups in general it is a learning curve but installation wise you'll know if its compatible before you even plug it in. because it wont plug in if its not compatible lol. sync 1, sync 1 with nav, and sync 2/3 use different plugs for the APIM. Sync 1 (little screen 13+) wont plug into a sync 2/3 apim. Sync 1 with nav (yours) wont plug into anything else. the base sync 1 that had the digital read out (lower option for the 10-12s) didnt have the provisions for a screen. Basically, what ever adapter or harness they provide should plug in to your APIM, ACM, and your bezel pig tails, if not I'd start getting worried about compatibility, the bezel being the biggest wildcard because I do not know for sure the panel does anything the screen cant, therefore you might not need the bezel plug.
From the listing I sent you, I see "power cable" which has 2-3 OEM style plugs, a canbus unit, and a couple other harnesses that likely branch off the main harness to plug into the head unit. It shows a mic and a GPS antenna so it probably doesnt use the cars built in units (the mic you might be able to reuse with some creativity) and an antenna adapter which you will definitely need. other peripheral cables appear to for added functions (4G antenna, usb cables, RCA in and outs) The only real issue I could see is the canbus settings, it should be plug and play if they set it up correctly from the factory for this car, but if not, its a generic unit so support is only with the seller id imagine.
Like you said, bite the bullet and report back, I know a few people that swear by the android upgrade over the sync 3 upgrade for the 13+ cars, but preference is less a priority over compatibility at this point.
