Best catless downipe exhaust setup
JP Strunc
Nebraska
Hey, just installed ppe catless downpipes and it rasps really bad in that 3-4k rpm range. Current exhaust setup is the downipes to a third cat delete with an x pipe to stock resonator to muffler delete. I was thinking flow master fx mufflers. Any thoughts? If anybody has any suggestions how to get rid of this rasp or tone it down a bid without sacrificing turbo noises too much that would be awesome. Thanks!
You will not get rid of the rasp without a better resonator and good mufflers.
Post 369
That is the set up from my old SHO.
3rd cat deleted, Magnaflow Resonator, into stock mufflers.
If I was in your shoes, I would remove the x, add a magnaflow resonator, and add magnaflow mufflers. You do not want to put a baffled muffler on a force inducted car, but the FX as you mentioned aren't baffled.
This might be an easy avenue of approach as well.
JP Strunc
Nebraska
Do you have any old sound clips with that setup? I also have stock mufflers I could throw back on, but not trying to buy a whole exhaust system.
JP Strunc
Nebraska
I do have my stock mufflers I could throw back on, but not trying to buy a whole exhaust system. I’ll have to look at your sound clips
In that thread, just scroll down.
JP Strunc
Nebraska
I saw that my ******* can figure out how to delete my reply smh
