It's been a minute but my car has been still A1 running strong as ever. Current mileage is 126k and some change. 2015 SHO if anyone asks. So Wednesday after a decent snowfall i was just cruising through my works property in one of our parking lots and i managed to get snow stuck under the car where the brake lines run down the passenger side under the car. Here is the ****** up part; There's a black plastic protective cover that got bent back severely causing this "grinding" noise to which i originally thought was drivetrain noise like the driveshaft, CV joint or worse, my PTU. I was not thrilled. Looked under the car and i see this cover bent back in half with a mound of snow wedged in between the brake lines. I jacked the car up and grabbed some loppers and cut the bent portion of this cover off and tossed it. Smh oops. Car is otherwise fine no other damage. Im not sure how important this "cover" is but i plan to either rip it completely off or replace it altogether. Heres the pic i took. Smh all of that noise for some plastic dragging? Lmao
