Austin2013SHO
Hey guys I finally got my HPFP installed today that I ordered from Gear Head. So had a few dilemmas along the way suck as there are zero videos or instructions on this thing. The closest thing I could find was a video from 5 years ago and either I have the wrong pump or they have updated the design. Mine came with a L shaped tip for my upper hose to connect to. They used to include a new fuel line in the kit but mine did not have that it had a 2 end thread on bend and a clip on fuel connector. These attach to the L shaped tip and connect to your original Fuel line. Bottom line threads right on after you remove your throttle body bolts (4 8mm) then loosen a 5/16’s nut to give this line some wiggle room to line up and thread on nut with hand at first then tighten its a 17mm.
My question may seem silly but does anyone know if the design has been updated or should there be a new fuel line and they sent me wrong pieces is this even the right pump for my car? Or am I just paranoid?
Also if you would like full installation and removal instructions posted let me know and I will make them as it was much different from anything I could see on YouTube
