PTU bolt hole broke suggestions
Scottie93
San antonio texas
the hole broke on the case of PTU am I ****** or can I come up with a solution with the help of the forum see pictures below.
In to deep on this new everything and my
Funds are super depleted any suggestions are welcome btw I have not located the broken off piece but am desperately searching
I don't have this model of SHO what is that hole for? Mount ptu to a frame piece? Hold 2 case halves together? A mount to secure another car part?
Cast aluminum or other metal? First idea is welding to repair broken piece or replacement. If it was steel I would think about welding a nut or a tube with a nut threaded on the end to replicate what is needed. Alum welding is much more difficult than iron/steel. Cast metal sucks in general. Here is something similar for aluminum Ford intake
Second idea is maybe an internally damaged PTU for cheap with a case or case part that you can swap over
Scottie93
San antonio texas
Yeah I’m looking into finding one that is damaged on eBay cause although I do have a welder it’s nothing fancy and I don’t wanna mess it up plus I still have not found the broken piece. I do appreciate your advice thanks . Super interesting video too.
Texas Marauder
Lone Star State
IMO, there is no reasonable way to repair that. How did you manage to break it? If there is debris in the hole hydraulic pressure will cause that kind of damage when the bolt is tightened. A used PTU case would be the only fix.
Tbird6
How did you break this? I have never seen or heard of this before?
Still gonna have to test a sample but.... Perfect station of the regular gas was 93 and not 87, but hey there is gas station right next door with 93...
