Air not coming out of 4 front vents
Joel Groff
Ohio
2015 Ford Taurus Sho…air will not come out of the four front vents nor the floor vents under the dash. Air conditioning works fine and so does heat. When selecting the air flow for dash to floor nothing keeps blowing out the defrost same when just floor vent selected and same when just vents selected. Just started bout a day or two ago. Checked fuses they are fine, disconnected battery to reset some stuff but to no avail. Do I have a blend door actuator go bad?? I think blower motor is fine as I get good air speeds no issue. Can someone please enlighten me on what this could be. No codes on the dash or stored at all when OBD-II scan was performed. Not sure what this could be. Any and all help appreciated.
Majestic
If the air is just coming out of the defrost, you have the super fun actuator up under the dash.
seasoned_shrimp
Kansas City, Missouri
Having the same issue currently - it's the (totally most fun) actuator behind the drivers-side dash and gauge cluster. There's a few posts around the forum that show an easier way of fixing it besides ripping half the dash out.
Deezuz
Indiana
Radio bezel, arm rest bezel, Drop knee kick, drop steering column, pull cluster, swivel 8mm and some trans assembly ****(to dip the socket in the catch the screw).
