Joel Groff
2015 Ford Taurus Sho…air will not come out of the four front vents nor the floor vents under the dash. Air conditioning works fine and so does heat. When selecting the air flow for dash to floor nothing keeps blowing out the defrost same when just floor vent selected and same when just vents selected. Just started bout a day or two ago. Checked fuses they are fine, disconnected battery to reset some stuff but to no avail. Do I have a blend door actuator go bad?? I think blower motor is fine as I get good air speeds no issue. Can someone please enlighten me on what this could be. No codes on the dash or stored at all when OBD-II scan was performed. Not sure what this could be. Any and all help appreciated.
