400 whp in a stock sho
wingingmean
New cumberland wv
You want more noise vent to atmosphere your blow off valves. I installed torque solutions... Others will tell ya to go chair leg cap however that how you get the pssssssst when the pressure releases
I've done that already plus took the damping material off under the hood. What's the turn around and cost on a ajp tune I think that is the direction I'm leaning towards with all your guys advice
Couple of weeks - he will also sell the timing device you choose
wingingmean
New cumberland wv
update, So far I have added AD mounts, Whiteline rear sway bar, Just got A sct livewire.
Ill be getting plugs, map and a tune in the upcoming weeks, looking to run mid 12's with these car. What to add next, still looking around the 400 to 450 whp.
BradM
Focus on exhaust next.
76FoMoCo
Nampa, ID
93 Tune! Then e30 if you have e85. Now the rabbit hole gets a lot more expensive
76FoMoCo
Nampa, ID
Lower MPG due to it Takes a bit more fuel to do the same work. And the there is the foot problem too.
tinkerkathleen
