lower engine shield
ato137528
Mississippi
The printing on it says it must be replaced for proper cooling and sound levels. I don't really care about sound levels but I AM very concerned about cooling levels, particularity the PTU to which I just added a drain plug to remove the sludge in it. How is this cover an aid to cooling? Seems like it prevents cooling. Looking for something else, I ran across FordTechMakuloco on YouTube doing an oil change on an Explorer with a 3.5 ecoboost. It didn't have a lower shield but rather an air scoop that points air at the PTU, that he acknowledges needs more cooling. THIS seems like The Way.
I don't drive in ice and snow or mud, but I do like the idea of the cover. But not if it's a hindrance to cooling. Thoughts?
Majestic
Yes, the Explorer tray is vented and would assist in cooling. The SHO tray doesn't do much of anything.
Ta2dResqr
Central Ohio
Agreed. I think the Flex is vented also. The other option is cutting the same opening on the Taurus shield. It has the same contours but, the opening is a flat filled in section on ours for some reason.
GTRPhilly
RI
I was in the same boat, I actually bought one and it’s sitting in the garage. However, there are two indents on the cover that look like scoops, but they are blocked. I’ve been considering using a dremel and opening up those vents and throwing it on.
That is exactly what I did. I used self tappers to keep the padding and insulation down.
76FoMoCo
Nampa, ID
No need to keep it. The advantage is on ford's side. You don't see oil leaking with the diaper under it until you are out of warranty. Had mine off for 70k and unless you live in the rust belt nothing is lost. My ptu oil looks great and if you put down pipes they hang too low for it.
Florida
cooling aside I read on here a while back it helps with the hood not shaking at high speeds having it in place. mines broken and held on with a big zip tie, so I would be interested in finding one off an explorer if theyre a direct fit.
ato137528
Mississippi
Thank you. I did the drain plug in the PTU mod and need to be certain it isn't leaking, plus I'm trying to find the sweet spot between not tightening the pathetic PLASTIC radiator drain plug such that it leaks and TOO tight such that it breaks. Need to be able to see drips on the paper on the garage floor. Diaper is off for now. Should run a little cooler with summer coming.
Texas Marauder
Lone Star State
The radiator drain plug seals with an O-ring in a bore. The O-ring doesn't tighten against anything. Just tighten until it stops. If it leaks, replace it.
1713894169489
Or this
1713894268750
Chris Gatland
My engine shield has been off for some time as one of the fasteners has departed the scene. Does anyone know where to buy these special worm style fasteners?
