1994 Taurus SHO MTX
Holiday
Canada
1994 Taurus SHO MTX in white. Selling as I'm downsizing to one vehicle. Will consider trade for a motorcycle depending.
Here are the details:
SHO edition of the Taurus with the 3.0ltr Yamaha engine with 5-speed manual transmission.
Body 309,000K, engine and trans about 208,000K.
Pros:
-No rust except a few small spots on one of the rear wheel wells.
-Clean interior.
-New alternator, battery, radiator, spark plugs, starter, fuel filter.
-Dual Borla exhaust with a Magnaflow resonator gives pleasing exhaust note without being obnoxious.
-Aluminum subframe bushings.
-Comes with 4 x Volvo 17" rims on all-season tires (also 1 spare) + 4 x original 16" SHO slicer rims.
-K&N high flow air filter.
-Auto everything + sunroof.
-Aftermarket Kenwood stereo w/ bluetooth, aux, USB with 2 new rear speakers.
-Keypad immobilizer anti-theft
Cons:
-Needs valve cover gasket as it's currently leaking oil. I am including a full valve cover gasket kit with related seals as well as a new intake manifold gasket set all from SHO SOURCE. Also including two new oxygen sensors which should be installed soon for best performance as the current ones are throwing a code. May need head gasket but unconfirmed.
-Needs front door speakers installed (only rear installed)
-A few small dimple dents here and there, a couple minor scratches in paint. A few small rust spots on one of rear wheel wells as mentioned above.
-AC has heat but no longer cold.
-Front passenger window slow roll up but I believe it's something in the door causing drag.
-lost one of exhaust tips recently so will require new tips and pipe from muffler.
-Will need a new coolant bottle sensor, currently reads low despite coolant being full.
Fun car, it's a classic, a sleeper, can be yours. Price has been reduced to factor in needed work. Will need to be towed. Currently price $2000 CAD ($1472 USD).
Located in Ucluelet, BC, Canada.
