2010 SHO- under dash fuse box
mission bc canada
removed my under dash panel expecting to see the fuse box - all i see is the GEN2 Remote Starter Module- want to remove # 41 fuse ( resolve sun screen thumps) where's the fuse box?
bpd1151
Lurking Around
SHOcago 'Burbs
Any pics of what you're looking at by chance?
Also, what do you mean by "GEN2"?
Sent from my SM-N986U1 using Tapatalk
mission bc canada
it says " GEN2" on the label and it is a ford piece - about a 3X2" block with the harness connected on rh side - car has the " button" with rubber boot on rad support by air box - don't really want to disconnect the harness - suppose i could remove battery cable first - never attempted to push my key fob - other than door locks -
Are you on the driver's side or passenger?
Sent from my SM-T860 using Tapatalk
mission bc canada
driver's - panel pops out above hood release and OBD plug is - thought the fuse box is on left side in that opening but that's where i see the flat face of the Remote Starting System module
Majestic
Fuse panel is on the driver's side kick panel up under the dash.
Majestic
removing the wide piece should expose it shouldn't it? i don't see it - bare metal brace and that remote starter module -
You don't remove anything to access it. It is where I explained. It's a pain in the rear to get to.
Majestic
This is what the cover looks like. Obviously, I never replaced it.
Cover
mission bc canada
hey ! found it - removed the cover - yanked # 41 blue 15A stopped the shade but power windows inop - need those windows - read guys were saying #41 - put fuse back - windows ok but shade a thunkin' away -
Majestic
Unplug the connector to the shade.
bpd1151
Lurking Around
SHOcago 'Burbs
I have practically a brand new shade for the 2010 model year, unused and collecting dust in my basement storage area.
I'll never ever use it myself due to the massive custom audio setup I have in mine. Not even sure why the heII I saved it TBH.
It would be a direct fit replacement.
I have no idea what it runs, but make an offer, and it's yours. Not sure what shipping would be, but it would be coming from 60451-3697.
Majestic
Good on you! I assume mine works but, I never use it. Kind of like my moonroof. Or my auto-park.
mission bc canada
thanks for the offer - I'll see if i can just disable it back at the shade drive - my old relic mustangs simpler to work on !
