Hub bearing non performance package or performance package
XIlasrn
South Bend
So can anyone explain to me the difference if any on a hub bearing non performance and performance on the front ?
SHOrod
Torrie Tuned
Cedar Rapids, IA
I don't believe there is a difference between bearings on the PP and non-PP cars. Have you been told there is? The bearings are also the same front and rear, one part number for all four hub bearings.
-Rod
XIlasrn
South Bend
-Rod
Thats what I thought till I looked on rockauto for my 2017 and theres a Non Performace and Performace I was looking at the Moog and Timken think they both have a non and Perfomace. So I guess its Throw dart time lol
-Rod
That's what I thoht till I staroking ted
-Rod
-Rod
AuburnHorseshoe
Central IN
Depends on which knuckle you have. Rockauto only had the performance package knuckle available this past month and the non pp bearings do not fit as the bolts are spaced slightly different btw pp and non pp knuckles and bearings.
XIlasrn
South Bend
Thanks Auburn Thats what i was wondering if bolt holes or bearing size was the factor!
LilCop2002
In the South.
When I did mine a few weeks ago on the 2010 Non-PP, all 4 were the same part number and installed without an issue.
SeanDev
There are differences, with my N/A interceptor for the front it was PP knuckle, but the rears all all the same.
Sho time in NJ
Millstone NJ
Thank you for the responses. I bought 13-19 knuckles for my 2010 SHO. Do any of you have bolt pattern dimentions for the PP and non-PP. Thank you
SeanDev
I do not, just my opinion but I think the PP is made more stout. Have done knuckles on my other two Taurus "SEL, Interceptor" and just completed this week front right hub bearing on my SHO, RockAuto has sent all correct parts for my cars. The only issue with RockAuto is anyone owning an interceptor must state the year as 2016 or up,. because if you own a 2013-2015, you will get all the wrong parts.
