2015 PP with 110k. Just had to replace mine. I'm in great northeast.The lower tube looks very corroded and wet concentrated at the bend, not fitting.
No sign of leakage where the axle meets the tranny or the tranny case/plugs.
Curious if anyone else has seen this.
I did not lose very much on mine. I did not take the hard lines from the transmission to the bypass block off. I did add the PP Transmission Cooler though and still only needed 1 quart total.Thanks guys. I have access to a lift and for sure figured that the airbox would need to come out to access at top. I'll see about the battery tray and between myself and neighbor (massive tool collection), we should be good.
Thought it would be an axle seal, so pleasantly surprised. Will I need more than 1 qt Mercon LV?
