ECT Sensor
JustinTN
Tennessee
2015 has been "overheating" the last couple days and message says "coolant temp overheating." I'm not much of a mechanic, but I'm almost certain it's the ECT bc it isn't actually overheating. After searching the internet and finding a YouTube video I thought was helpful, I started removing the intake, among other things. After struggling, and researching some more, I think the vid was for the CHT. Before I put things back together, can someone tell me exactly where the ECT is located?
Thanks!!
JustinTN
Tennessee
Update....I was finally able to locate the sensor (on the side of engine block....drivers side). After a lot of researching, I could only verify the SHO has a single temp sensor...not both a CHT & ECT. Unfortunately, this didn't fix the issue, so I'm wondering if anyone else has had similar issues or has any other ideas.
About a week ago I noticed my temp guage started dancing around while driving, but it was more load based. If I was driving up a hill &/or applying more gas it would increase. As soon as I started coasting it would almost immediately decrease back to normal levels. There was no smell, smoke, rough idle, etc....just the temp gauge.
Day 2 and beyond had been the same except for the temp guage would now max out and the dash would light up with "engine coolant overtemperature." Still 0 other symptoms and no check engine light. As soon as I coast and the temp guage comes down, the message goes away.
No leaking found, coolant levels full, fans coming on, no belt noise, etc which imo rules out all the normal things that would cause it to actually overheat.
Is there possibly another sensor that I'm missing? Or could the male electrical end that plugs into the sensor be the cause? I don't want to keep driving it as is, bc when the guage redlines the computer thinks it's overheating and it goes into a "limp" mode. The moment it comes back down it runs completely fine. Any help is greatly appreciated!
JustinTN
Tennessee
Sensor location
Ta2dResqr
Central Ohio
Any codes? Is the thermostat working? Does the coolant look clean? Anything blocking the radiator?
JustinTN
Tennessee
Coolant and oil are both clean. 0 codes. Nothing blocking the radiator. I have not removed the thermostat and tested it, but since the temp guage is dancing all around and not staying hot or cold, I gotta assume the thermostat isn't getting stuck. Definitely scratching my head.
Is there a way to attach a seperate gauge to monitor temp and see if the oem gauge itself isn't faulty? Even just a quick sensor/gauge swap underhood and let it run and rev it to get temps up? I would consider the t-stat for replacement just based on age at this point. Up to you but small price for confirmation. Also you could remove it and run the car a bit and see what difference there is as far as current high temps
Ta2dResqr
Central Ohio
Did you check codes or is there just no constant light? Can you live view data and see what temperatures are? If it is getting hot enough to bury the gauge, it should have a code.
JustinTN
Tennessee
If there is a way to attach an external guage, I'm clueless....good idea though if it's possible. As for the tstat, of course mine is a little pricier than the oem due to livernoise, but I did already get one. I might go ahead and change it just for the heck of it.
JustinTN
Tennessee
I hadn't scanned for codes until yesterday, after swapping out the sensor and it still not fixing it....0 codes. That's why I was 99% certain it was the sensor since even though the guage will spike, I don't think the car itself it truly overheating. I'm still wondering if cutting off the electrical component that plugs into the sensor and rewiring a new one will help.
tinkerkathleen
