Kebabaluba
I read in instruction manual that normal gas tank volume is 16 gallon but there was option of extra large tank at 18 something gallons. How to i tell what gastank i have on my car, any spesific code in VIN i can read?
Unfortunately this is the only way to truly know. The v6 SHO was supposed to get the 18.5 gallon tank but several ended up with the 16. My 91+ had a 16 in it and I swapped in the 18.5. When the light comes on you should have around 4 gallons left in the tank. If you keep track of your mileage then you should be able to run it pretty low and then fill it up.Run it close to empty and then fill it up?
I was hoping to learn it less risky way of getting stranded somewhere, these cars are not economicalRun it close to empty and then fill it up?
Since manual states that 18 gal tank was an option, that can`t be seen anywhere in options code or VIN? As per today i parked my SHO with fuel gauge on the last bar before red zone with fuel gauge flashing. That means i have 4 ish gallons left, whis is about 15 litres of fuel?Unfortunately this is the only way to truly know. The v6 SHO was supposed to get the 18.5 gallon tank but several ended up with the 16. My 91+ had a 16 in it and I swapped in the 18.5. When the light comes on you should have around 4 gallons left in the tank. If you keep track of your mileage then you should be able to run it pretty low and then fill it up.
-Chad
I'll say. If you are new to the car, you don't know the half of it.I was hoping to learn it less risky way of getting stranded somewhere, these cars are not economical![]()
just carry some fuel in the trunk when you run out fill it up and subtractI was hoping to learn it less risky way of getting stranded somewhere, these cars are not economical![]()
That’s good to know, Irish. My 2013 light comes on pretty much exactly at “50 miles left.” 4 gallons is a lot more than that, esp on the highway. The amount I can pump is less than what I’d estimate. The interpretation is that the light and the readout are over-conservative. Probably a good idea!Unfortunately this is the only way to truly know. The v6 SHO was supposed to get the 18.5 gallon tank but several ended up with the 16. My 91+ had a 16 in it and I swapped in the 18.5. When the light comes on you should have around 4 gallons left in the tank. If you keep track of your mileage then you should be able to run it pretty low and then fill it up.
-Chad
Yes i`m quite new to this car/platform. Some things needs to be learnedI'll say. If you are new to the car, you don't know the half of it.
Funny thing about country i live in, you might get a ticket if you let your car run out of gas and cause traffic jam or something. So i would not try to run my car empty of gas, its expensive as it is for the gas, a ticket is just rubbing the salt in the woundjust carry some fuel in the trunk when you run out fill it up and subtract
