I talk like that and I’m 41 lolDope! (my 22 year old son said that)
What do you mean in layman’s terms lol? Are you talking about Matt and his estimate or are you also saying what I hope to make will never happen or that finally I’m on to something and or delusional?Sorry, I just SMH'ed so hard it almost rolled off my shoulders. For 700 HP? 700 ft-lb? Try 550 ft-lb. How people so entrenched in the aftermarket can be so clueless is bewildering. No wonder it's taken 12 years for the platform to get to the point you're at now!
Thank you I agreeAre you sure that's a SHO engine? That SOB looks like it ought to be in a Ford GT. Awesome shit there. As always.
Tying back to our convo a few weeks ago, the notion that your cams are going to make you peak at 5200 rpm is beyond ridiculous. Stock SHOs peak at 5500. Feels like every ATP dyno sheet I've seen peaked past 6000 RPM. An NA 3.5L peaks at 6850, and so does an SHO out of boost. All have the same "sh.itty" cams. The only cars that peak at 5200 are those with a certain turbo "upgrade".What do you mean in layman’s terms lol? Are you talking about Matt and his estimate or are you also saying what I hope to make will never happen or that finally I’m on to something and or delusional?
**** yeah! That’s what Max Power was saying I should make 600 wheel on a low boost 13-14 psi tune and that the GHGen3R would be so far out of efficiency it wouldn’t even be funny.Tying back to our convo a few weeks ago, the notion that your cams are going to make you peak at 5200 rpm is beyond ridiculous. Stock SHOs peak at 5500. Feels like every ATP dyno sheet I've seen peaked past 6000 RPM. An NA 3.5L peaks at 6850, and so does an SHO out of boost. All have the same "sh.itty" cams. The only cars that peak at 5200 are those with a certain turbo "upgrade".
You're addressing the single largest impediment this platform has: obscene backpressure ratio. You're going to make so much power so easily. Like, take whatever you made with those gen3's and add 20-30% at the same boost levels. With no added stress to anything. Just by letting the engine breathe and not succumbing to BS marketing of rod twisting nO cOmPrOmIsE tUrBos.
Just for reference. A guy here in the AZ Lexus community has a 2 1/2 inch down pipe on his 2J with a 76 mm turbo. He stepped up to a 3 inch down pipe and picked 70 hp on the same boost and decreased this turbo lag by almost 1000 rpm.Tying back to our convo a few weeks ago, the notion that your cams are going to make you peak at 5200 rpm is beyond ridiculous. Stock SHOs peak at 5500. Feels like every ATP dyno sheet I've seen peaked past 6000 RPM. An NA 3.5L peaks at 6850, and so does an SHO out of boost. All have the same "sh.itty" cams. The only cars that peak at 5200 are those with a certain turbo "upgrade".
I don't think anyone thinks the cams are limiting power to 5200 RPM. Obviously restrictions are causing the problem. Better cams would improve breathing at higher RPMs. But they would likely really only come into effect above 6500 RPM if we did have better cams. Breathing in the is everything, but you need to Exhale as well.Tying back to our convo a few weeks ago, the notion that your cams are going to make you peak at 5200 rpm is beyond ridiculous. Stock SHOs peak at 5500. Feels like every ATP dyno sheet I've seen peaked past 6000 RPM. An NA 3.5L peaks at 6850, and so does an SHO out of boost. All have the same "sh.itty" cams. The only cars that peak at 5200 are those with a certain turbo "upgrade".
Lol well that is extremely optimistic. I was thinking 600 whp around 18-20 psi.**** yeah! That’s what Max Power was saying I should make 600 wheel on a low boost 13-14 psi tune and that the GHGen3R would be so far out of efficiency it wouldn’t even be funny.
Hopefully I can tell you, although I don’t see any Mustang dyno pulls in my future. Tuning for time only. Dragy will be my time dyno. Tuning for a 10 sec street pass before hitting the track. I’ll be able to report then what psi it took to accomplish that goal. *no nitrous*Lol well that is extremely optimistic. I was thinking 600 whp around 18-20 psi.
600 wheel is going to be my 87 octane tune![]()
So sexy that I just want to mount it! Slide it right in, to my engine bayEngine **** time! 90% done with turbo orientation. Rest needs to be in the engine bay to complete. View attachment 83633View attachment 83634View attachment 83635View attachment 83636View attachment 83637View attachment 83638View attachment 83639View attachment 83640View attachment 83641View attachment 83642View attachment 83643View attachment 83644View attachment 83645View attachment 83646View attachment 83647View attachment 83648View attachment 83649View attachment 83650View attachment 83651
Much better lmfao
Such a smooth, shiny, inviting, bald head.
