CRC GDI Intake Valve Cleaner
jasong_10
Croghan, NY
Found this on the shelf at work today.
IMG 20220113 083913
CRC products are usually pretty good stuff, any thoughts, experience?
Bluezone
Ont, Canada
Works good on my MKS. Even checked it afterwards with a borescope.
yaycandy
Aerospace Engineer
Hanover, PA
Best stuff to use. I used it with the intake manifold off once and it worked better than any other cleaner i tried. Pea cuts the carbon right off. Cleans the turbos and exhaust manifolds also
jasong_10
Croghan, NY
In regards to using it, obviously I would prefer not to take off the intake, and it gives two methods on the can. The "professional" one is to remove a vacuum line that leads to the intake, and use that as the entry point. The "diy" method is to remove the intake tube and spray through the TB. Honestly, it seems like they've got the "professional" and "diy" backwards as the vacuum line sounds like the much simpler/easier method.
So how did everyone do it?
Thanks.
withku
Phx, AZ
Thanks.
i sprayed it through my vacuum line, didn’t clean anything though. granted my valves were pretty bad
