PCV System Questions
jasong_10
Croghan, NY
I've been going through the collection of threads we have on here regarding catch cans and came across some info on the OEM PCV system.
1. Normal driving/no boost it operates by pulling clean air from the intake tube pre-turbo into the front bank (clean side) and it exits the rear bank (dirty side) and is routed back into the intake post-turbo/pre-TB.
2. Under boost, the PCV closes
and/or
3. the circulation reverses.
I have a '12 PP, can anyone verify if any or all of this information is true for my application? Thank you.
jasong_10
Croghan, NY
That makes sense, reversing circulation maybe wasn't the right way to word it, one of the posts mentioned that with the PCV closed under boost, it causes "dirty air" to be pulled out of the "clean side"/front bank pre-turbo. Where as under non-boost conditions it is the entry point for clean air heading to the crankcase, hence the "clean side" label.
withku
Phx, AZ
pcv only flows one way, just closes under boost.
bank 2 replaces air in the crankcase due to vacuum.
jasong_10
Croghan, NY
So is there a PCV/one way on both banks, one on the rear that only lets air out, and one on the front that only lets air in?
FrankK
Colorado Springs, Co
Here is a good article explaining how the PCV system works on a turbo charged engine.
Frank
jasong_10
Croghan, NY
Frank
Thank you, that cleared things up (if I'm understanding it correctly). The way I read it, in non-boost situations the vacuum from the intake pulls the pressure from the rear bank/"dirty side" out of PCV and into the intake. Not sure what the front/"clean side" PCV does . . .
Under boost the rear/"dirty side" PCV closes and the vacuum from the turbos pulls the pressure out of the front/"clean side" PCV into the intake track.
I'm just curious as to whether or not my car has the OEM oil/vapor separators that the article mentions.
