Swapped my tires for Winter's, lubed the caliper pins and pad shims.
Found both rear tires severely worn on the inside to the point that air was visible from the outside (not really but steel threads sticking out).
Installed (finally !) the rear camber adjustment bolts I bought months ago and in the process found that the upper back control arm bushing have plenty of play in it, so now I'm looking for replacement parts...
Video
In addition, I tried to decipher why my parking brake fully engages on the right tire but barely on the left.
The Workshop manual states "T
his tension pulls on the RH rear parking brake cable. At the same time, the tension in the front cable causes the RH cable conduit to attempt to straighten out, causing tension that pulls the LH rear cable."
I don't see the second part happening, by the time the right is locked, the left has barely moved. Can't find a way to adjust the left side so if anyone knows how, I'm all ears.
