Lookie at what arrived today.
Already installed. Two and a half hours to get the old stuff off and an hour and 20 minutes to install.
Yeah buddy!
looks like it was mid to upper 70's with a 2k DATemps during run?
It was about 75 degrees out.Temps during run?
Humidity was around 50%. Temperatures were dropping rapidly. I calculated. A da of a little over 1500 or 1300 depending on which calculator used.looks like it was mid to upper 70's with a 2k DA
Only the finest enginerd'en here eh. LolLMfnassoff love the redneck intake box! one thing with the hot pipes I have found the edges on the flanges for the bov are sharp and the fit is very tight. I ended up sanding the sharp edge off to make if a bit round to help prevent cutting the bov diaphrams when you install them.
It's not an easy job it's tight in there. Have to watch it for core shift as well as these are castings.i like where this is going definetly am onboard if this works....(starts dusting off the dremel)
That's too bad it would have been an interesting Benchmark to compare against. I suspect though it might have been limited due to the attachment of thermostat housing to the intake manifold. If you go for a drive in cool weather and put your hand on the manifold you can clearly feel the heat from the thermostat end. While the throttle body and will be cooler.We've had a few others in the group including John Diaz go through and coat and thermal wrap everything when we had the phenolic spacer group buy a while back, but never really got any good data to back up the differences that I saw.
