I've adjusted the valve clearances on over 90 cars. While I've rarely found a clearance that was higher than the max, I've found plenty that were close to it. I only adjust clearances at around 120K, despite the Ford recommendation of 60K.
I change all 24 shims, setting the clearances at the bottom end of the range. Now the valves are fully bedded in, the gap can only get bigger, not smaller. Gives an unnoticeable increase in power, and prolongs the service interval. But on a new engine, or after valve work, the clearances should be set in the middle of the range (6-10 thou intake, 10-14 thou exhaust). One has to allow for the gaps to reduce a little as the valves bed in, as well as them to increase through normal wear.
I follow the normal practice of flipping shims over and using the pristine underside as long as there are no scratches in which case the shim shouldn't be used. Shims I take out invariably have a one thou cup in their old working surface, so if I need to reduce the gap by, say, three thou, I choose a shim that will only reduce it by two thou.
Problem with flipping shims is that the shim size stamped on the underside gets erased. So it's important to keep a record of all the shim sizes. Here's a handy spreadsheet to do that:
https://www.dropbox.com/.../Valve%20clearance%20template...
Wait for the sign in box to appear, then close it. Use the down arrow top right to download it.
Although Ford shims are no longer obtainable, shims for BMW bikes work great. Here's a spreadsheet with a parts cross reference for the V6 and V8 engines. The one caveat is that they are only available in two thou increments vs. Ford one:
www.dropbox.com
Shim tools and kits here:
https://shosource.com/products/ols/products/sho-source-shim-kit-rental-deposit-89-95
