Jordan's Rebuild Plan of action
Jordan_R
Missouri
So little timeline of installation for those interested.
2pm engine on stand just finished fully timing it and installing timing cover
5pm all additional stuff added turbos, intake manifold etc etc with a trip to ace
7pm first start
9:30pm majority of front end installed and drivable lol
Made decent time yesterday. Drove it around today about 30 miles to make sure no CEL and begin break in. Going to go a couple hundred miles before feeding in moar boost
bpd1151
Lurking Around
SHOcago 'Burbs
What's it sound like now? An audio clip perhaps when time permits?
I'm confident the followers and fellow SHO owners would appreciate that.
Jordan_R
Missouri
I made a video on the youtubes. Can't figure out how I'd upload a clip over here so here is the video of me starting it up. Crude editting so for those looking for just the sauce skip to 2:30 on the video! First start the exhaust wasn't hooked up so it was a little loud lol. 6:40 for exhaust hooked up sound
Jordan_R
Missouri
Brad tuning it?
So what turbo's?
Gearhead and Brad both are tuning it. Albeit their own tunes lol don't want people thinking it's a collab and I'm running the GH Gen3R turbos which are speced like ATP but a little more effective. Billet compressor wheel and a couple other tweaks.
76FoMoCo
Nampa, ID
Cool! I know this is a peak into the secret sauce but whats the end goal for psi?
Jordan_R
Missouri
It'll probably end up somewhere around 25psi I'd believe!
Also got home about an hour ago and threw on the front end. Glad to have all these pieces back on the car and not in the garage!
IMG 20210516 210056
jtreber
Indiana
7pm first start
So what was the final verdict on the oil pressure issue?
DadMobile
Texas
Lawdy 25 psi is awesome. I think I put down in the neighborhood of 520whp with an average of 18-19psi. You should be close to 700 awhp with similar torque I’d imagine? Let’s see some 10.3’s or 4’s :)
Jordan_R
Missouri
I made 536awhp at 20psi and 19 degrees of timing on my gen3. Matt said Gen3R should make another 15hp at same boost but now we can also turn up the timing to compliment it lol!
Jordan_R
Missouri
Sorry, didn't scroll up, but the issue was plug behind water pump again. Used the manufacturer number on the plug on my original block to track down a part number and replace with the OEM one which is a rubber coated metal plug.
What is the break-in protocol if I may ask?
Just gonna drive it around for a couple hundred miles and lots of engine braking
Jordan_R
Missouri
Welp! Considering my break in miles done! Like @Bluezone 's video I don't believe in the long long break in mileage etc. Basically what I've been doing is I broke up the break in to 30-40 mile rides at a time.
First drive easy acceleration with lots of engine breaking.
Second drive like normal hitting few psi of boost with engine braking
Third drive hitting about 10psi with engine braking
Fourth short stints of WOT with engine braking
So first start up due to a lot of machine work I let the engine warm up, verify oil pressure, bleed coolant and once it was up to temp I did a filter and oil change. This way you can make sure the machining stuff that didn't get cleaned out is gone from the engine. I then added just some cheap oil and a ZDDP oil additive (zinc additive) to for the break in miles. Now it's time for the expensive oil. From @mattr66 's suggestion went expensive and going to run driven 5w50 full synthetic. About $12-13 a quart but rather do it safe than sorry! The engine is built a little "looser" for the more power so going this direction just helps making sure everything stays in the correct place!
IMG 20210519 220058
limited02
Olathe, KS
No more Amazon oil, huh?
313tiger
