Jordan_R
Ah, more than one way to skin that cat, I see. I had tried that method first, but it didn't work for me. The wire harness turned into the issue. But I may not have worked through it all the way. Gave up and went the other route.
If you clip the wiring harness off of the fuel rails you can have more wiggle room to put them on. This is what I did last time around as I didn't like the tightness that the rails and harnesses had together. Felt like I was forcing something that was binding up. Now I just run the harnesses completely separate from the rails. No clue why they zip tied them in the first place.
