High on Ethanol
Just Ain't Care
You already have it. It's on our computer. Duh!
We have separate accounts though.... You don't use the same password as I use on my luggage : 12345
That's a weak password. Mine is much better.We have separate accounts though.... You don't use the same password as I use on my luggage : 12345
I don’t have my computer in front of me but to command is like 60% or 65% from the factory. Of course there are a few likely ways a tuner could inadvertently screw that up without ever touching AWD settings though.My prediction? Folks are gonna break their drive trains.
But...if we pioneer a way to safely and affectively send 70% or so of torque to the rear wheels on a permanent basis...
I'm OK with people breaking their stuff!
Yeah, but that's only after the front loses traction.I don’t have my computer in front of me but to command is like 60% or 65% from the factory. Of course there are a few likely ways a tuner could inadvertently screw that up without ever touching AWD settings though.
Not sure what the limits of the clutch pack in the RDU is, but it's likely not high enough for that 70/30 split as it currently sits. But, we'll never know until someone tests the limits of these components. And maybe there's a viable option to beef up the rear that we haven't discovered yet...Yeah, but that's only after the front loses traction.
I'm talking, full time, rwd biased AWD. I wager these cars would be an absolute blast to drive with a fulltime 70/30 split. Enough to put the power down from a dig, and still behave like a rwd car for the rest of your driving exp.
Even a 50/50 full time split wouldnt be bad. Especially if it wasnt a reactive split as it currently sits.
I know in skyshadows thread about the hybrid setup he mentioned he figured out he rear end was a dana 28 I believe. Simply knowing that should open up at least some potential for beefing it up. I havent looked into that much, so maybe Im way off but it seems like a start.
Nope that’s not how it worksYeah, but that's only after the front loses traction.
If its a 28, wouldn't a Dana 35 swap be possible?Even a 50/50 full time split wouldnt be bad. Especially if it wasnt a reactive split as it currently sits.
Its how mine works. I mash the gas, the front tires chirp and a half second later rapid forward motion is achieved.Nope that’s not how it works
Sorry Lee. I wasn't trying to knock you in any way. Apparently that's how it came through so I apologize. I just find it weird that my 2016 has had all of these new parameters since the day I got my MPVI.
You know, for the longest time I've been under the impression due to the design that the right front axle and the PTU were mechanically locked as a cheap-ass afterthought attachment and that's where all my ranting about the open front diff comes from. Nobody's bothered correcting my ignorance. But today I think I'm finally realizing that the PTU is splined to the carrier itself and not dependent on the differential as I've been ignorantly believing.
If this is true then 1) I'm a idiot and 2) I'm kicking myself for having to played with these settings sooner! Although...
The resolution is jacked up, but I do have AWD duty cycle in all my logs. I don't know if it's supposed to be % or what, but multiplying the logged values by 10,000 puts the RDU command at 4.6% when stopped, peaking at 92.6% around 16 mph, then slowly tapering off from there:
There's a few other parameters I'll be adding to my logs too:
It will be interesting to send those AWD torque requests to the moon and see if this duty cycle signal goes up or not. I've got a very simple two-step I'm working the bugs out of and am currently able to leave on any amount of boost I want. Trouble has been getting the timing to ramp back in quick enough for it to matter. And without the supporting traction I decided to just let it go by the wayside and abandoned it.
Now we are getting somewhere!!I mean...I suppose we could just drop a taurus body onto a gtr drive train...
