Did my very first Dragy run...opinions?
Ecoboost_xsport
Sacramento, CA
...kinda did it on a whim as I was actually datalogging for Brad to dial this tune in a bit better, it still needs some work. I've had this Dragy for a while but never really used. Said to myself, "Self...let's try out this new-fangled magical box".
60' time sucks ass...last time on the track, prior to 90% of the mods I have now (was on stock turbos, etc.), I was able to get some low 1.9s 60' times consistently. Had my tire pressures at my street pressure of 36psi on this Dragy run.
Wanted to get your opinions. Good run? Mediocre run? Those who drag more often (track and Dragy) , what kind of times you think I can see had I run a low 1.9 60', and dialed in tire pressures...
...considering the World Record for my platform is currently 12.62 @107.75 (actual track time, not Dragy)
y4m_wbbr03LREm2w-3P7WwKXm-592JEip820WaYFbffy7XQSXlL_cX1qvx9Uxp1vfysIi3XVg42Nxg4N8uMltdix9be6f9eMqPmlCY00aCbTW0r8hj8IrUN8jqTI8UMWlMtEFuVz6ifQqRACkUepNI3x8Xf8s-e5EOjG44c2oq_ngv0d6f1SGFjid7PCo7f3MT5
y4mtVeM1Z8tlXmm7igyKeWRu4MyIMNr0l2Gu6G2cNpok1LE6kXWYP2r4ExzD3DGIAfbv-j42aRc79KQA6qLCP6Vu1DC8m4OOW6tJfNruZQr_6sA1WxmunM_CsTaji1wwCJwvsnENtBYPoifjrpEvwEGPDL9l5FJs5qdDV0FiIxNVzpi_kr45lDkza80WkS-76iI
Jordan_R
Missouri
Easy couple tenths on figuring proper launch / psi. Then on a strip my time is usually about 2-3 tenths faster than on dragy from prep etc. I think all and all looks like low twelves in your future pretty easily. 1.8 second 60' on the street in sho on dragy is usually about the best you get. Obviously better on strip
ridered74
I'd say you should be setting a new record for your platform.
My track 60' is typically a full tenth faster than the dragy 60' time, and the 1/4 mile time is usually 3-6 hundredths faster than dragy time.
The only thing that may hold you back at the track is heat soak.
76FoMoCo
Nampa, ID
Dragy has been almost dead even with my track time slips. what I found is what ever time your 60' increases you will see about 2x that on the back end. I do believe the record for you platform is held at my track (firebird raceway) he has a lot done to it and runs it seats out.
Ecoboost_xsport
Sacramento, CA
Small world. Yup its a your track, I know him personally, so if ya ever see him out there, tell him I said whats up, lol. He comes out here to Sacramento occasionally, that's how I know him.
That's his XSport on the right....crazy small world, lol...very cool.F811bdcec7fa93c54bd6393dec3b8526
76FoMoCo
Nampa, ID
LMFAO very small world. it was fun watching him go from 14.s we talk a lot at the track and I told him meth is good for .2 to .4 but he is resisting.
stripSHO
Idiot Savant
Detroit
With a proper launch 12.2-12.3 feels likely. I’m surprised after all those upgrades though that you’re only up 3 mph
Ecoboost_xsport
Sacramento, CA
Yeah, something is going on with the transmission...the 1-2 shift takes waaaaaayyyyy too long, sounds a bit like it's slipping before 2nd fully engages...it's very pronounced. Also, I'm still early on in tuning and Brad has it set pretty conservatively as we dial this e85 thing in. Having issues with the LPFP (even with DW300c) not keeping up with demand...got a BAP installed and datalogging as we speak...
1b8a62ad53028c9e84c21d7db4a99f0f
76FoMoCo
Nampa, ID
This was his record run. Look in the top R corner of the picture 20201126 140740
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
Add more trans fluid. I like to keep things in their proper range but adding another half quart really seems to be helpful. Mine used to do that too. Not sure if it was from adding more fluid or different tune revisions ...on or the other or both but it’s pretty much a thing of the past. Also it just might be too high of rpm....want to say if it’s shifting just shy of 6000 rpm 1-2 also seems happier.
For one the slope of the track is going to be much better...you’ll be faster bc
1) Slope of track very flat
2) Track prep better 60ft
3) Dragy is notoriously slower by hundredths
4) Tune dialed in more
5) should have quarter tank of gas no more, even if not removing seats take any extra stuff out, head rests, floor mats, remove loose belongings in the glove box and center console.
6) Use race fuel if you can. Always better no matter what than pump E85.
7) Purge your methanol manually...give it a couple purges it’ll drop your IAT2 down a good 15 degrees or so. Start cooler end cooler.
shobroooo
