ATX vs MTX Battery Hold-down Question
Old Stang
Woodstock, GA
Hello,
I'm piecing together the OEM battery tray/hold-down mechanism for my 94 ATX and I believe I have an MTX hold-down rather than an ATX version.
My research seems to indicate that the MTX version has an offset hold-down fender mount tab and the ATX version has the same tab closer to the middle of the long side.
Does anyone have a side-by-side pic of both versions (or single pic of each) for comparison?
Many thanks,
Marc
Irish Pride
Irish Inside
MusicCityUSA
Ill post a pic of the MTX one in my 92 later today when I get outside. I might have an ATX bracket in my shed. I'll look when I get home.
The main difference is the MTX tab comes off at an angle because the battery sits at an angle. The ATX tab comes off perpendicular because the battery sits straight.
Irish Pride
Irish Inside
MusicCityUSA
Well, I thought that I had an ATX bracket in my shed but everything I found matches whats on my 92. Now that I'm thinking about it, I'm unsure if the hold down bracket is different between ATX and MTX. I know that the battery trays are different because of the way they sit on the car. What might also be different is the mount on the fender wall that the bracket attaches to. The brackets might be the same but the fender mount might be different. I'll let you know for sure when I get to work tomorrow.
20201111 215312
NoSlo
SHO Owner
Portland, OR
The ATX bolt tab is definitely right in the middle, and it is a "fork" instead of a bolt hole, so you can slide it off the loosened 13mm nut.
iirc, the atx allowed a larger battery to fit also due to the added drag of turning over the torque converter.
Old Stang
Woodstock, GA
All,
Many thanks for the replies.
... great info. :)
My hold-down bracket looks like the one in the pic posted by Irish Pride, so it looks like I'm still on the hunt for an ATX hold-down bracket.
... and the correct size battery... LOL
Any pics of an ATX version bracket and/or other info still appreciated. Thanks again.
Marc
email Dan Barbush and see if he has an ATX available. He parts cars out at good prices. SV&HOdan on the forum. You can usually find him posting in classifieds or wanted to buy section
Irish Pride
Irish Inside
MusicCityUSA
If that's what the ATX bracket looks like then I think I do have one. I saw one that looked like that but just figured someone cut it to make it easier to install. That's what I do to my battery trays. I'll look again tonight.
Old Stang
Woodstock, GA
Thanks, I appreciate your efforts!
Marc
Irish Pride
Irish Inside
MusicCityUSA
This is what I have. The battery tray holes were already cut so I just figured that the bracket was cut too. Can anybody confirm that this is an ATX battery bracket?
20201112 215714
20201112 215824
Irish Pride
Irish Inside
MusicCityUSA
3.2 battery bracket
F3DZ-10718-A
3.2 bracket mount
F3DZ-10727-A
3.0 battery bracket
F3DZ-10718-B
3.0 bracket mount
FODZ-10727-A
Irish Pride
Irish Inside
MusicCityUSA
This one needs a wire brush and some epoxy paint to really look good. Not rotten, just surface rust. If you think you can use it, PM me an address and I'll drop it in the mail this weekend.
-Chad
