I didn't even know that much fluid fit in there.
It doesn't. When I filled mine using the fill plug, I only got about 14oz, roughly, into it. He got an entire bottle of shock proof out of it.
Actually, it does, technically, "fit" but it's only supposed to be filled with 18oz, according to Ford Service Manual. It's not supposed to be overfilled, but looks like his may have been, or trans fluid is leaking past a seal into the PTU.It doesn't. When I filled mine using the fill plug, I only got about 14oz, roughly, into it. He got an entire bottle of shock proof out of it.
What would be the downside of overfilling it?
Easton seems to be letting us know how overfilling has so far causes no issues. Damn trans shop going nutty on his fluids. 32 oz is nuts but maybe 20 would be for good measureHeat causes expansion....also depending on how compressible it is...could get interesting.
My PTU has leaked past the shaft seal since I bought it. I guess the reason I never care to address this is because it’s never accumulated to a single drop on the ground...so it can leak a little for all of eternity for all I care...as I’ll replace the PTU entirely before replacing just a sealTypically, anything significantly over shaft seals is leak prone. Lip seals just dont do well in that respect. Jordan, if you see the thread again, heigth wise, where is the fill hole in respect to the axle shafts on your PTU? Picture in your thread looks about even, but its hard to tell.
That’s cool you helped him out! What did his fluid coming out look like?I have been working on this SHO today.
Drilled and tapped the PTU and RDU. Things went smoothly. Replaced both fluids with Redline Lightweight Shockproof. Trans got a 5 out and 5 in. His PP SHO didnt come with a traction control button. It was a factory mistake. So we purchased one and I installed it. Car is smoother and the new owner is happy.
Not one bit. Hot turbo air will take care of that rather quickly. Plus a minimum amount of water going into the engine (if any) really doesn't affect performance.Once you freeze the IC are your concerned with moisture developing inside the intercooler itself?
Yup, would be just vapor anyway. Not to mention, methanol injection kits often use various ratios of water-to-meth to keep combustion chamber temps down so a bit of water vapor is not unheard of...Not one bit. Hot turbo air will take care of that rather quickly. Plus a minimum amount of water going into the engine (if any) really doesn't affect performance.
