Got my X35 Phenolic Spacer...
Ecoboost_xsport
Sacramento, CA
Looks like a great product and look forward to getting it installed to see if it can mitigate IM heat soak issues further. At the time of this write-up, he didn't have it listed on his website (X35Design) but emailing Steve over there will get you the info you need.
When I mocked it up and placed the hardware in the holes so I can see if I would need to do any port matching, I found it suffered from the same issue as the BBK throttle body. Not the fault of the spacer, but more the fault of the IM. The bolts holes are just too large for the hardware and allow for a lot of play. This would make any attempt at port matching it futile as it would be difficult to place properly when installing it. So...just as with the BBK, I used the same logic here. And it worked perfect...
Spacer with gaskets installed:
DyaRCT09uzarLwidth1024height1024cropmodenone
Thickness of spacer for those curious:
CtoVtEYf3Qv0awidth1024height1024cropmodenone
Dowels created for improvement:
5/16" OD, 0.035" wall thickness, 304 stainless tubing, cut to about 0.8" length (can't be any longer than 0.9")
JAeK 1K9WclV2width1024height1024cropmodenone
Picked any 2 holes far apart from each other and drilled with 5/16" drill bit:
0VMELpyqOdqa6width1024height1024cropmodenone
Drilled matching holes in spacer, same 5/16" drill bit:
DTlRstyZ8n48Swidth1024height1024cropmodenone
Dowels installed into spacer:
6R1aZZ7Cr9frDwidth1024height1024cropmodenone
Perfect tight fit onto IM:
KW3uuAliZOsL1width1024height1024cropmodenone
Will need minimal port matching, mostly just a little of the spacer needs to be matched to the ports, but Steve did a great job of getting it super close.
There ya go. I can probably drill the bolt hole very slightly using the same 5/16" drill bit for the match holes in the heads and push those dowels through the spacer slightly. That would get this setup 100% dead-nuts tight and centered from head to spacer to IM...
Here is a video showing the port matching done on the IM side of the spacer:
On the head side, another 5/16 hole only slightly drilled to accept the alignment dowels:
YWvR3PSs5zNq width1024height1024cropmodenone
Both holes drilled (hey, easy now...this is a family oriented forum!):
WNx8Ug3rphVoJwidth1024height1024cropmodenone
This is all you need it pushed through on the head side to get it to line up:
Qv4XU7WVjp1f6width1024height1024cropmodenone
Rags stuffed into runners to minimize getting the dust into them while doing the port matching:
Fun4US S4K2vuwidth1024height1024cropmodenone
Used the dowels and the hardware to keep it secured down while porting:
B9rPXb9k2uIrVwidth1024height1024cropmodenone
Video on doing the porting on the head side of the spacer...
All done and ready to mount:
EfFGxd20K4dpswidth1024height1024cropmodenone
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
..and think I found a small way to improve it...
Got it today and looks like a great product and look forward to getting it installed to see if it can mitigate IM heat soak issues further. I still need to order the additional gaskets before I can install it.
When I mocked it up and placed the hardware in the holes so I can see if I would need to do any port matching, I found it suffered from the same issue as the BBK throttle body. Not the fault of the spacer, but more the fault of the IM. The bolts holes are just too large for the hardware and allow for a lot of play. This would make any attempt at port matching it futile as it would be difficult to place properly when installing it. So...just as with the BBK, I used the same logic here. and it worked perfect...
y4mouSrmr0xxRk0g3EJJNqX1TgtEgyq512xAol6wej8_SrtiB9bkMPT0VnC_DkJY9bkAaP55zA1cV0ks9ycbj9vI8UCC-pIxyOMLWzbJ3n19zRIbI_RvOKnKC7UoiAj62vK4gOsiYS4mMwSi21FwgdnRoZ2dcHCCZMN8a8SHx3FY85bBpGIuLo2nXoxO86Ae8gAqggNRO8x4GM5EKP6vYh4xg
y4muktOz2x5V8SOzdVPp_P5oPX1Ez3D0tWULmTWFPX9viqNPUrFe-0y2KrZEozUSt65rm1q2QeQLl3CgtUX4bXEKZUz0Eq5rcOybQp-YKxB0tMgiuxYv7qcP1WfY9STRgGXFADPEgSPW9smb82ciVL-4GP8CNgemrlnTXsXwWM5tfsLFB25qrzQMaSzK13bUgL5KpRkfAoNKY3wRNxgevTPLg
5/16" OD, 0.035" ID, 304 stainless tubing, cut to about 0.8" length (can't be any longer than 0.9")
y4mdcSu3PnSSNZWb2fjxdu5fGXzttbaSECQMKuCTxT3mkJ0yaXO4IX7tRK-nd9VIbdJpirjmgS0ymoWE4NIoUlXKTs9C3VK-5BNCoZGX-SZTnHn1glisg-9lb4WvztL9CAsa1FrbX8UDMd9bQAmP8oU11fN_8Ja7PIGoaZba6hcs2LHopGpYy9ambaQNAfrRhgK_vOlckh7QAalFD6RbwLV3A
y4mHR3GgmY9svd9kLda-R1cKQSCrXEfa_DQXTEH2apszv5C_8gSQqs5ECREn3vX0oIzJ5qtSEJnKZ6owVpkZFmMoRhpcjHW3kiW4kx6khM5hcwFdFPaxn7_jRxh3NePxpgda0J8beRQsGRszRcsekF6ytjA4wi_5DEYsJfYlVr-roeTIYvpPUomyFDgPFBuEGJzGCWUF02Pdf9VHIjmVT2QcQ
y4mgLwkbhjXJ_4Abki5PWf2eXZF9GEMqTwQ5X2nrxJCfqObmw0-i_TMkSHUB4cZRQptVPEdmp_71-iOZdA8yeobCu-KQZY4hkUWG9wAn0ujXXv0Ts3hu8GbhmeE69g7OXB4xzF3lmxNT5pjH-FGRXSu7rLbZ9wZ3XHizP1PxNi8rI9BgXkJVYtM9veb5rN1chsb6XBwZuevWWslIe1puJomkA
y4m0jKWOMKrOtgwHIwuaeCbFfIgoVqMogN_rOX9zorXPhSkieXm-Za9FEcWhN3fHSdE1gbpDadCahM4g3g7bw1PArOYnDb8v_5lgnUXiMLfRqZ2MYUE6Gmgz8AvXHOcbJflAUE_Futsy6DEzNUiinUwX6OzbTb2ACv8xEe1AwSSZDdzbp-JK1rNBLz5JXoAor8MM59biUha93pU7hqgO7xzoQ
y4mbU69Wi3_rjGI_jFoHtcMLYK46pTWeN7yXkr3BjCZ3zUoZzT3Pc94SRJ1KUga6m4k-7y1ovrkHwlzY-QsewsuKRXIoWrkr1LGwuLv-UdxpyZPIRT-h004yNifzeusIGIrgtqPoUm-rInzygEfkytzCmcO_GVtscX8XVbPQ8UiG_X26jgnLbZT89jOcVWnl9bl0flz-aheJTSbM34i2zbiYw
I feel like a loser having mine for as long as I have instead but still haven’t even started the engine. I found I broke my radiator drain plug when I went to tighten it, bc I used a power tool.....to loosen it. But I’ll have it breathing this weekend and should have some data. Since I had it off I should have wrapped the coolant pipe but of course I didn’t.
Ecoboost_xsport
Sacramento, CA
Man, I've been there myself....lots of times. I feel your pain.
Non HERCULES!!!!!
Ecoboost_xsport
Sacramento, CA
Can you send me some? LOL. I'm having mine port matched as we speak but I do love a 100% for sure fitment
I guess I could. I ran out of materials on the set I just made last night. I'd have to order more. When do you need it by? I have to order the materials in decent quantities though, so maybe there is am interest from more folks on this?
Jordan_R
Missouri
I'm still probably a month or two from completion on the motor at this rate so no real rush from me. If you don't end up making any that's just fine also
Ecoboost_xsport
Sacramento, CA
hmmm, Anybody else interested? I could do these sets for, let's say $20 shipped. I'm not making much. About $8.50 is shipping ,PayPal takes 4%, plus cost of materials (per set). I'm making lil more than $5 a set for my labor, LOL...damn, I might need to charge more haha.
GotGrip?
Conversation Ruiner
Will you stop breakin' shit?
Ecoboost_xsport
Sacramento, CA
Haha...well I went and ordered material. Should be here in a few days, then I gotta spend some time on the lathe to crank these out.
I'll let you guys know when I have a few sets done.
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
Awesome. My manifold was Powdercoated last night and should ship Monday. Got me all excited.
