EPP vs. AirAid
ridered74
Anybody have a contact for EPP? Still haven't gotten a confirmation of my order...
Mike also works a full time job, so sometimes communication is a little delayed. It's been a while since I ordered from his website, but I want to say it is automated and usually you get a confirmation order as soon as you order, or within a couple minutes. I could be remembering incorrectly tho.
As for the benefits, I've never been a big fan of basing anything off dyno charts or singular runs even if they are back to back at the same track. I can run the exact same setup same day and be off a tenth. That's just how it goes.
I probably went to the track 30 times last summer, most times I'd get 4 or 5 runs, a few times I'd get 10 plus in one visit.
Every single trip to the track, my times were extremely consistent with the exception of three track visits. The time I switched wheels/tires, the time I removed my front trans mount, and the one time I went with a stock airbox compared instead of my airaid (had it in while I cleaned the airaid and just forgot).
Those three times were the only times my car failed to make it into the 12.2's. I would usually have 2 or 3 12.2's, 2 or 3 low 12.3's and one or two runs that were just over 12.4.
At least with my car I believe the airaid is good for a tenth or so over the stock box.
I haven't been to the track with the EPP intake as of yet, but I've been forced to switch to my slower wheel/tire setup and so far using dragy it is a little over a tenth faster than the times I was able to achieve with the same setup last fall.
15SHOPP
Cincinnati
An intake will make your wallet lighter which may help ET's but I'd just go with a drop in, JMO
Depends how far down the rabbit hole you are...
With my current mods, the intake helped reduce the WGDC up top which allowed me to carry the requested boost levels further throughout the revs. I'm maxing out the stock turbos with my current mods and will be 110% maxed next week when I add on the meth kit.
This intake really shines once you upgrade the turbos, or so I've heard (probably a late 2020 or early 2021 mod for me)
crystizel
