Yes. But there shouldn't be a loss of performance. Your ecu targets load, not boost. Colder Temps require less psi to achieve the same load. Also when you said 19 psi before I assume you were referring to a transient peak and not real loaded boostDoes ambien temperature effect how much boost computer commands?
Now as it all of a sudden got colder, in to mid 20's low 30's, I am back again to 12PSI with OAR at -.96
High intake tamps because of the heat soak, you are correct.
Filter not in the very bad shape but needs to be cleaned for sure, I will take care of that this weekend.
I am thinking to do smoke test myself to check for leaks over the weekend and I still thinking boost solenoid is possible issue, I have new one coming tomorrow will swap right away.
Why do you think waist gate is trough the roof, what would cause that?
19psi was peak not loaded boost, you are correct
Once I had intercooler installed, Matt at GearHead did tune revision for me, he sad waistgate needs to be adjusted to compensate for larger volume, that is why they are so high.
Thanks for input
He is correct, the upgraded intercooler is on the verge of being to big for the stock turbos.
I don't know that I'd say it's "too big" for the stock turbos, but the added pressure drop is almost too much for them to overcome.
I gained 50hp with it, but it's harder to maintain boost without maxing the wastegate. Commanding 18 psi and when the converter locks it starts to taper off to 14 up top. I bought TurboSmart wastegates to try to hold pressure better but like everything else I have no time to install.
What intercooler did you go with? and can I get a link to itI don't know that I'd say it's "too big" for the stock turbos, but the added pressure drop is almost too much for them to overcome.
