1995 Supercharged-Intercooled SHO
Status
Not open for further replies.
MLNIUMFLKN
Salt Lake City, Utah
***Car sold. Thanks everyone.***
I've been holding onto this car for a very long time, but it's time to let go. Over $30k invested from 2001-2007. See full list of mods below. Car has been sitting outside since 2007 due to a 3rd gear failure. In 2013, Toolman was awesome enough to sell me his premium SHO Shop rebuilt, Quaife'd MTX with approx 5k miles on it for $1,700.. it's been sitting in the backseat ever since. The car made approx 500 whp and leaves an impression on me to this day. My intent was always to keep her and get her running again, but it just hasn't happened. So please, someone get her back on the road again! - nothing would make me happier.
Approx 14k miles on the SHO Shop built 3.2 Liter. Approx 100k miles on the chassis. It's been sitting outside so it needs paint, but there's very little rust.
Asking $4,000 O.B.O. to recover only a small percentage of what I've put into it, along with the $1,700 very low-mile MTX that's sitting in the backseat ready to be installed.
Here's the full list of mods (I have invoices for everything) and some pics...
'95 Taurus SHO
ENGINE:
SHO Shop 3.2 Liter 9:1 compression
JE Lightweight Forged Aluminum Pistons
SHO Shop Hi-Flow Heads ported-matched to intake runners
Extrude Honed Intake Runners (powdercoated silver)
SHO Shop BigBore Butterfly Valves with air horns removed
SHO Shop HYPERformance Stage II (RACE) Camshaft Kit
3-angle Valves
68 mm Throttle Body
80 mm Lincoln Mass Air Flow Meter
SHO Shop LPM with custom programming
SHO Shop Underdrive Pullies
SHO Shop Engine Support Package which includes:
Front & Rear Reinforced Engine Mounts
Transmission Mount
Heavy Duty Subframe Insulator Kit
Engine Torque Limiters
SUPERCHARGER / INTERCOOLER / FUEL SYSTEM:
Vortech V-2 S-Trim Centrifugal Supercharger
Reichard Racing Ultra Grip 2.90" Supercharger Pulley (16-17 psi @ 7,000 rpm)
HKS Blow Off Valve with K & N Filter
Custom Cold Air Intake with K & N Filter
24"x12"x3" Front Mount Air-to-Air Intercooler (2.5" inlet/3" outlet)
Snow Performance Boost Cooler Water/Methanol Injection System
SHO Shop Double Core Radiator
47 lb Fuel Injectors with modified fuel rails
Walbro 255 LPH Fuel Pump
SHONut Fuel Pressure Regulator
DRIVETRAIN:
SHO Shop rebuilt 5-speed MTX (approx 5k miles)
Quaife LSD
South Bend Dyna Max DXD SS Puck Clutch
SHO Shop Aluminum Ultra LiteWeight (8 lb) Flywheel
SHO Shop Short Throw Shifter with Steeda Shift ****
SUSPENSION:
SHO Shop Canyon Carver Race Level Suspension Package which includes:
Intrax Linear Performance Springs (lowered approx 1" in front and .75" in rear)
Koni Adjustable Insert Struts
Full Body Subframe Connectors
Front and Rear Strut Tower Braces
Rear Adjustable Tubular Control Arms with Reinforced "H" Brace
24 mm Front Sway-Bar (from an '89 SHO)
29 mm Rear Adjustable Sway-Bar with Polyurethane Bushings
Heavy Duty Suspension Bushings Package
Heavy Duty Subframe Bushings
Heavy Duty Outer Tie Rod Ends
BRAKES:
Front: Baer PBR 2-piston 13" crossdrilled/slotted rotors with Baer carbon metallic brake pads
Rear: SHO Shop Rear Brake Kit with SHO Shop brake pads
EXHAUST:
SHO Shop Headers (titanium powdercoating)
SHO Shop HiFlow Y-pipe (no cats)
Custom 3" CatBack Exhaust System
MagnaFlow Resonator
MagnaFlow Mufflers
MISCELLANEOUS:
Tech Edge Wideband o2 Sensor
MSD Knock Alert Sensor
Pro-Comp Ultra-Light Boost Gauge
White Face Gauge Kit
Steeda 3-pc. Billet Pedal Cover Kit
Odyssey PC680 Lightweight Battery
20191015 173104 20191015 173037 20191015 173124 20191015 173131 20191015 173212 20191015 173223 20191015 173309 20191015 173459 20191015 173617 20191015 180757 20191015 180325 20191015 180249 20191015 180238 20191015 180300 20191015 180310 20191015 173806 20191015 173603 20191015 173437
MarcusKars22
Back in the Game
American Fork, UT
If texting is easier my number is +18014521536. Lmk I’d love to come check it out.
TIRESHREDDER
pa.
Asking $4,500 O.B.O. to recover only a small percentage of what I've put into it, along with the $1,700 very low-mile MTX that's sitting in the backseat ready to be installed.
'95 Taurus SHO
ENGINE:
3-angle Valves
68 mm Throttle Body
Transmission Mount
DRIVETRAIN:
Quaife LSD
SUSPENSION:
BRAKES:
EXHAUST:
MagnaFlow Resonator
MagnaFlow Mufflers
MISCELLANEOUS:
View attachment 10898 View attachment 10899 View attachment 10900 View attachment 10901 View attachment 10902 View attachment 10903 View attachment 10904 View attachment 10905 View attachment 10906 View attachment 10907 View attachment 10908 View attachment 10909 View attachment 10910 View attachment 10911 View attachment 10912 View attachment 10913 View attachment 10914 View attachment 10915
TIRESHREDDER
pa.
Ok, Great, Was the car used for racing or just cruising around ? It doesn't really matter cause I just want It for the parts. I'm just curious . Sorry for the communication delay I didn't see your response till now.
MLNIUMFLKN
No problem. Same here. It's never been track'd, only street driven.
MLNIUMFLKN
Did I miss it ? What kinda of power did the car make??
No, you didn't. It's still available. It wasn't dyno'd after the 3.2L and some of the other mods, but it's definitely 500+ whp. To give you an idea, my Evo X dyno'd at 530 whp and the SHO is still faster.
Status
