1995 MTX - Green/Gray
rjd1995
SOLD!
2-Owner Colorado car, I've had it since 2010 and put on less than 10,000 miles. 114,500 miles.
At 105,100 miles (2010) had some transmission work, brakes, starter and subframe bushings replaced.
(aluminum bushings were on order but not received in time so the standard ones were installed but I have the aluminum ones)
2012 received hail damage that broke the windshield and rear window, both were replaced.
Between 2012 and 2016 changed timing belt, radiator hoses, water pump, thermostat, spark plug wires, vacuum hoses, CPS, ignition switch and probably more that I'm forgetting.
At 110,800 miles (2016) replaced the fuel tank with a used one (the fuel gauge hasn't been correct since then)
Around 112,600 (2019) replaced rear shocks with Monroe Quick-struts (standard replacement)
At 112,700 new tires - Goodyear Eagle GT (rotated 8/2023)
- Runs great
- Seats aren't in bad condition besides the lumbar air bag not holding air.
- New battery
- Miscellaneous dents dings and scratches
- Coolant overflow reservoir is cracked
- I think the fuel evap canister needs to be replaced, gas smell on hot days and long drives
- The little timing belt cover access door is missing, replaced it with a piece of license plate metal with the work in 2016
I think the MAF sensor needs to be cleaned due to some lagging on acceleration when the car's warming up, on my to-do list.
The pictures show the seat covers on the front seats - they are not hiding anything, the cover padding just disintegrates when peeled back. I can get better pictures of the seats if needed.
hosbaldosho
