Hi temp 1 time
MrCRKLPOP
casa grande az
I was sitting in the drive through with the ac on. It was 60s outside and the temp spiked but then returned to normal once i started going and stayed steady. Got home and popped the hood and found this. Where is the tstat in our cars. Could this be why my heat isnt working as well?6d2d97b7b3dca8ffc0a1b48b7641419aBb721f38d55d4b9ac867c40e7675ad29
Coolant leak? If the coolant level in the degas bottle drops, yes, that can affect cabin heat performance.
Recently one member had a similar situation in which replacing a cracked hose was the solution. He put it on video.
MrCRKLPOP
casa grande az
It looks like the spray is pressure relief from the cap. My thought is the coolant got too low and it got hot and caused it to build pressure
MrCRKLPOP
casa grande az
I dont see it leaking anywhere it just looks like it sharted out of the cap
MrCRKLPOP
casa grande az
So i topped off the fluid. Heat works woohoo and i did notsee any leaks but will keep an eye on it over the next few days.. also did a thing... debadge and dechrome rear rest of car over next few days9190bad980aa973ad2d17981a67ed430
ridered74
From the looks of the picture I would guess it shot up out of the reservoir. Fyi, thermostat is on right side of front of motor, to the right and a little closer to firewall from your front rightmost spark plug.
Jeff2017
Did the gauge spike or were you looking at something that monitors the core engine temps? My Blue Driver will show the temp go up when sitting in traffic as well. But never much over 210-215 on a hot summer day.
Keep an eye on it. The 5.0L has known leaks from o rings that shrink in the coolant hoses and can leak very little as the coolant cools down and the rubber o ring shrinks a little.
MrCRKLPOP
casa grande az
I will be watching it closely.. engine temps arent anything to mess with.
Also bring your SHO to the Pavilions this weekend. I will be there and I can check out your SHO and give you some pointers on what to look for with these cars.
Johnbigdog
michigain
Pull the engine apearance cover, lock at the block above the alternator. There is a plug with a small hole above it. That's the weep hole for the water pump.
