Dynomax 39502 Stainless Steel Exhaust System Install Help
SHOmeDa$$$
PA
I recently purchased the Dynomax ultraflow axle back exhaust and the install instructions suck! So is the muffler supposed to slip over or inside the OEM exhaust because it is exactly the same diameter pipe and either way I go seems not to fit at all. can’t believe nobody else has had this problem?
SHOmeDa$$$
PA
Ok, figured it out. Just gotta stretch the tabs a little to get it to fit OVER the OEM exhaust pipes. Fits good once you stretch the tabs.
305SHO
South Florida
How do you like the dynomax? Any drone? Thinking of buying this same kit but also removing resonator and plumbing in a x pipe
shobroooo
