skyshadow07
I'm now second guessing running 5w-20 instead of 5w-30. I am actually doing a 1000mi clean out oil run with Royal Purple.
No, oil pressure sending unit. My daughter has this issue with her EB Flex. We (yes, she helped) changed the oil, filter, and oil pressure sending unit, and the low pressure light went away. The sending unit was covered with oil, so maybe leaking. I think her Flex had over 100K on it at the time.I assume SHOdded meant oil filter there.
From SHOdded:"Change the air filter, it might be causing a restriction." I assume he meant oil filter as air filter has nothing to do with oil pressure...No, oil pressure sending unit. My daughter has this issue with her EB Flex. We (yes, she helped) changed the oil, filter, and oil pressure sending unit, and the low pressure light went away. The sending unit was covered with oil, so maybe leaking. I think her Flex had over 100K on it at the time.
Yeah, it's below the exhaust manifold, passenger of the oil cooler and above the oil pressure switch. Very tight area, I could not see it directly, only with the camera.What is that? engine block?
