I recently picked up a small power inverter that I would like wire into the car. I'm sure someone here has done this already. Anticipated use is just to power a laptop or charge small batteries that don't use a cigarette lighter or USB charger, so the draw should be really low (the inverter can be plugged into the cigarette lighter and works fine). I was wondering where to place it and where to tap into power.
My first thought was under the passenger seat, which would allow access to power for both the seat heater and the motors. Thoughts?
And yes, I am aware that a dedicated line to the battery is best for an inverter, but since this is low-draw usage, I figured I may as well try splicing in somewhere. If I wind up blowing a fuse, I'll know that it is too much of a draw for the wiring. And no, I will NOT be putting in a bigger fuse to compensate, I don't want a carbecue.
