BRAKE FLUID CHANGE
Johnbigdog
michigain
5 pints is overkill.
1 to suck out the fluid from the reservoir and replace the build you sucked out. Due to reservoirs size this isn't much. Then 1 pint for each corner. This will get everything out.
And if you can, use a vacuum bleeder (or pressure bleeder) so your master cylinder doesnt get run though any debris in the cylinder and damage the seals..
