factory alarm
plumber
mi.
Hello . My 1993 SHO has a ford 600 plus alarm system. Does anyone have any info on how to disconnect it . I'm tired of having to reactivate it every time I unhook battery to work on car. Thank you Plumber
sperold
Last to Know
The EVTM (Electrical and Vacuum Troubleshooting Manual) makes no mention of an alarm system, but does have a section on car phones, so it seems to be complete.
You may need to look in the archives for options on the Mercury Sable, as they had a similar model to the SHO but fitted with the 3.8 Essex engine. It may have been a dealer installed option on the Taurus / Sable.
plumber
mi.
Thank you. Yea I think this will be a tough one to find info on it. Plumber
plumber
mi.
Thank you for responding, I will keep looking. Plumber
NoSlo
SHO Owner
Portland, OR
$60 for the alarm on eBay.
S l1600
According to this 2001 post, DIP switch #3 on the module will turn off automatic arming. The module was made by Code Alarm and uses their transmitters and procedures. I didn't quickly find a 18 pin + 5 pin wiring diagram though.
I would expect that if you unplug the brain, it will probably disable it. It is possible that there is a relay or two that has been installed that requires an "on" signal from the alarm module, such as a starter or ignition ****. I have such a system, actually kind of cleverly wired if I can pat myself on the back.
plumber
mi.
S l1600
Thanks for info. I would like to read the instructions but letters to small. Someone gave me things to check so I'll see what I can figure out. Plumber
