SHO us your wheels
Bluesrocker137
Pennsylvania
20 x 9.5 et30. tires 275/40/20
Sorry to bump this thread a bit, but you're running 9.5 inch wheels with a 275 on all 4 corners? I've fallen in love with Rotiform KPS wheels, but I've been extremely hesitant to run a 9.5 inch wheel, or anything larger than a 255 tire. Wheels have a 35mm offset, I dont plan on going any lower than what you already have.
JasonoftheRugar
Wisconsin
Yes, all 4 are the same
Bluesrocker137
Pennsylvania
The rear rubbed. Not the front. The tire slightly hit the inner plastic of the fender. Fixed it with a heat gun. You going with a 35mm offset will most likely not experience this issue.
Good to know. I might go with a 265 tire to play it safe regardless, depending on what options I have within my price range. Thanks for the info!
OmaHahn
Omaha
I'm online shopping and it shows two hub options: 71.5mm or 73.1mm Hub. Which ones are yours (ours for the SHO)?
Christian
Chilliwack BC CANADA
Here's my setup I got installed today. It was a lot of fun at the tire shop with all the tire installers and customers gathered around my car. They were full of questions - "I thought they stopped making these years ago", "I bet she really moves", that sort of thing. They loved the staggered look, as do I. I have no plans to lower it. I just can't give up a quiet, smooth and compliant ride in this DD. I know how much better it would LOOK, but also don;t want it to ride like my son's Subie BRZ. In the photo you can also see how I blacked out the window trim. THAT was a nightmare. I think I'll take it all off and have a local shop do it, (same shop that did my grill and roof). So many bubbles, wrinkles and such. Good from far, but far from good. SHO 1 20190319 165237 20190319 165313 20190319 165355 20190319 174740
Poppa Diezal
Tampa
I really like the stock rims, but these look great. Seems especially worth it losing 5lbs per wheel. Nicely done!
Sent from my SM-G950U using Tapatalk
OmaHahn
Omaha
Here's my setup I got installed today. It was a lot of fun at the tire shop with all the tire installers and customers gathered around my car. They were full of questions - "I thought they stopped making these years ago", "I bet she really moves", that sort of thing. They loved the staggered look, as do I. I have no plans to lower it. I just can't give up a quiet, smooth and compliant ride in this DD. I know how much better it would LOOK, but also don;t want it to ride like my son's Subie BRZ. In the photo you can also see how I blacked out the window trim. THAT was a nightmare. I think I'll take it all off and have a local shop do it, (same shop that did my grill and roof). So many bubbles, wrinkles and such. Good from far, but far from good. View attachment 8649 View attachment 8650 View attachment 8651 View attachment 8652 View attachment 8653
Sorry if I missed it - but what wheels are these? Size? Looks awesome, love the contrast of the white and black! I;m going to throw Curva Concept C300 on mine soon hopefully. If you have the PP, lower it!!! The PP has stronger suspension, shocks, etc - I installed H&R springs and it rides perfectly fine!
Christian
thanks Omahahn
The wheels are Niche Misano M119. Gloss black.
Fronts are 20x9 +35 offset. tire is 245 45 20
Rears are 20x10 +40 offset. Tire is 275 40 20
Tires are Cooper Zeon RS3 G1 , which are a new product that Cooper calls "our best, most advanced, all-season high performance tire designed for owners of performance vehicles"
The Curva c300 looks real nice as well.
OmaHahn
Omaha
thanks Omahahn
Fronts are 20x9 - 35 offset. tire is 245 45 20
Rears are 20x10 - 40 offset. Tire is 275 40 20
Thanks for the info - do you know what hub size? I see all kinds of different ones like 64.3, 72.1, 74.3mm, etc... Did you have to install hub rings?
Christian
Sorry mate, I have no idea on hub size and I checked my invoice. It doesn't say.
Also, I edited my post above. I hyphenated my numbers which made it look like -35 and -40 offsets. They are +35 and +40.
OmaHahn
Omaha
How did you know they would fit then if you didn't check hub size? Just curious bc I don't want the mess of returning wheels/tires, etc. Thanks.
OmaHahn
Omaha
Tire shop ordered them. They knew the offsets, etc.
However, a simple Google search says it's 63.4mm.
Correct, simple Google search always works, BUT... I haven't seen one wheel offer the 63.4mm option. Never ordered wheels for my SHO and looking for a little help.
