That output looks low... Did you verify that the oar had reached maximum?
Looks low how? 3 runs and those were the best numbers. This is to the wheel on a conservative Mustang Dyno.
EDIT. ..Didn't know you are with GH
Depending on how the car reacts to the octane it thinks it has, it can limit both boost amd timing. At -.8 oar you have full boost, at -.96 you have full boost and timing. OAR of 0 is basically 87 octane and makes 15 or so hp over stock with that fuel. -.96 is about 93 octane and 400 whp if the iat2 stays cool enough (below 110 degrees) and about 350 if your iat2 gets up to the typical 160+ degrees. The tune is very reactive to fuel and environment like the factory but better. A better intercooler will help a lot as well.Looks low how? 3 runs and those were the best numbers. This is to the wheel on a conservative Mustang Dyno.
So I agree with points 1a,2,3...
Point 1: Sparing the gory details of leaning out a mixture, adding sparking, or boost etc etc... what are you using as a baseline for “safe”?
I have always wondered but don’t have the data or means for something like AFRs... your tunes run richer than any tune I have had...I know where Gearhead targets and it’s leaner compared to your tunes. At what point with these cars do leaning out the mixture not net you much of any additional power? I have always been curious given the same spark/boost what leaning out the mixture on these get you?
There is a lot information about GDI motors being able to safely run leaner mixtures due to the nature of direct injection as apposed to port injection..
You are in the ballpark with stock exhaust on a mustang dyno.So you're saying I'm about 50whp less than I should be on this tune? As mentioned couple posts before I run nothing but 93 and I even added a little over 1 gallon of e85.
Also on Mustang Dyno.
If i temembwr
I have Magnaflow cat back, would DPs help that much more?
DPs help more than catback.I have Magnaflow cat back, would DPs help that much more?
Did it take out the 3rd cat? And yes DPs help a lot.
No, my exhaust shop wouldn't touch the cats.
So basically the biggest advantage of the cat back exhaust is taking out that third cat like Corsa does... otherwise it’s just noise...
Well the pipes are bigger and mufflers are straight through so I hope it frees up things a little bit. Corsa doesn't eliminate the cat, it's just the 3rd center muffler but I believe there's still some type of baffling with those center pipes.
Corsa goes all the way to the flex pipes on the down pipes. Which does remove the third cat.
https://www.carid.com/images/corsa/exhaust-systems/pdf/14315blk-installation-instructions.pdf
No point in having power if the shifting sucks. Definitely would stand my ground on dialing it back.
Also, Corsa has an XPipe function built into their turbo/catbacks.
Too many maybe's. I work in the plant that produces our motors and can guarantee you each and every little change is documented. The process is called 'manage the change', and you'd better bring your data, as the revision will be scrutinized by many departments both in and outside the plant, including vehicle operations (VO) Changing the length of a bolt by 3mm could take up to two months to get approval.It is neither difficult nor unsafe to grab datalogs at those rpms, think of highway ramp merges on inclines for example. So if someone is willing to try and corrobotate, that would be cool. If not, it is what it is, I guess
Ford keeps making changes in production, some that are documented some not. In the process of solving a problem or using a new supplier, new issues can be created. Orb maybe reached the limits of the intended design ... IDK.
Trying to cover the bases. We tend to look for flaws in software because that is the way the world works today. How much do we really understand about the hardware?
Hear hear. intercooler!And we're all looking forward to that product release.
Hopefully soon! **fingers crossed**
