6500rpm
This was kind of interesting, it came up on a monthly Tech call we do with GM. This was concerning cleaning DI systems. The tools and process are GM related, but I can see cross over uses. The links below are generic from a quick search, but the tool part numbers are correct.
Application: All models with gasoline engines with Direct Injection (SIDI)
EN-35800-20 is used with J-35800-A Fuel Injector Cleaner to remove carbon from the upper intake tract, from the back of the throttle body and from the valves on SIDI engines. Previous PFI systems introduced cleaning product through the fuel injectors using previously Essential J-35800-A Fuel Injector Cleaner, which attached to the fuel injection supply lines. On SIDI engines, the injectors are in the combustion chamber of each cylinder, and will not introduce the approved cleaning product into the intake tract. EN-35800-20 is installed between the intake snorkel and the throttle body to allow introducing the atomized cleaning product ahead of the throttle plate, and allow it to reach the entire intake tract. Once positioned, the valve on J-35800-A is opened, allowing atomized cleaning product through EN-35800-20 to clean the intake tract while the engine is running.
https://www.handsontools.com/Kent-Moore-J-35800-A-Cleaner-Fuel-Injection-J35800-A_p_26258.html
https://gmtoolsandequipment.com/en-US/Pages/ItemDetail.aspx?SKU=EN-35800-20
