change battery, air blowing feet windsheild
Omar
CA
guys , I've changed the car battery since I owned the bull for 4 times , nothing went wrong or weird , my last one went little differnt, I've changed the car battery after it went dead , each time I turn on the AC , air blows feet then windsheild , then give me a hot blow , then finally it goes cold , it takes about 3 seconds , not a big deal but it's annoying , any idea what's going on there ?
Omar
CA
already did , twice , same still , I heard about actutator claiberation ! a fuse I have to disconnect , ever herad of that ?
Johnbigdog
michigain
Pull fuse 46 in the body control module for 1 min. (Ignition off). Replace fuse and turn ignition. Wait 30 seconds before checking blend door operation.
Is the HVAC in auto when this occurs? What about manual function? Blowing warm could be a refrigeration system fault too.
Omar
CA
well , I pulled the fuse , it worked like you said , appreciate your help John.
shootinirons
