Pulling to the left
jazzplr
Lafayette, IN
I'm getting ready for a road trip with my son and had the tires balanced and rotated yesterday. I've noticed now that from a stop the car pulls to left a bit when getting on it but drives straight otherwise. Could it be a geometry problem with tire dimensions being a little off from not being rotated in 10,000 miles?
krewat
Long Island
Check the tire pressures. If you had one back tire a little low, you won't notice it much. Put it on the front where a lot of torque (and of course, the steering is), and you might get a slight pull.
jazzplr
Lafayette, IN
Definitely going to check that when I get home. I think the pattern they used was back to front and then cross front to back. I haven't looked in the manual yet to see if that's correct / recommended.
shobroooo
