New v11 tune update!
Bronco2fan
Texas
Yeah mine's here. So not to sound stupid, but how long does it take to download? My tuner has been flashing starting system please wait for 5 minutes. Plus when I installed the tuner updates applications it said tuner error code 2753.
Sent from my LGLS991 using Tapatalk
OmaHahn
Omaha
My first Cal device was junk and gave me error codes and would always fail half way into uploading tune in my car which is very bad! But LMS and their great service gave me a new tuner device! This one works great! You might be going down same path.
Bronco2fan
Texas
Hmmm. Worked fine on the first upload when they sent it to me. If it doesn't do something soon I'll start over.
Livernois Motorsports
SHOForumSponsor
Dearborn Heights, MI
Try unplugging it and closing the app and restarting it and check your firewall as well
OmaHahn
Omaha
Pm me if you change your mind! Hes flooded with all of the requests and im trying to help him take some of the load off with these!
Anthony emailed me yesterday and I uploaded the tune - I only had one chance to use the full potential of the 93 tune on the on-ramp! Seems excellent but the real test will be from a dig. My last V11 would have issues during the shifts from 1st to 2nd and sometimes 2nd to 3rd - car didn't shift at all and appeared to slip into Neutral somehow because the engine at top of the gear right when it should shift would red-line and smoke pours out the exhaust. I just had a new PTU installed and transmission work done about 1,000 miles ago so it can't be those parts failing.
SHOForumSponsor
Thats more than likely caused by the tires not grabbing and when they dont grab the car will not allow it to shift, sometimes different tires as well as over filling the ptu slightly and making sure traction control is off will help this out alot!
OmaHahn
Omaha
I don't know if it's a bad habit, but I always turn TCS off when I start the car. The only solution I've found so far is to shift manually. But still very happy with LMS!!!
Bronco2fan
Texas
I had a chance to run the **** out of her this morning. So far so good. Ran like a scolded cat. No harsh shifts or hesitation on accelerating. But that was just with tranny in sport mode, everything else on still.
If I get a chance this weekend I'm going to try with everything off and real sport mode lol.
SHOForumSponsor
Glad your enjoying the update and sounds good let us know!
gimpy
Pennsylvania
I simply cannot give Anthony over at LMS enough credit. Not that I'm not thanking the LMS associate that is responsible for posting here.
Everyone involved with the mail tunes at LMS are a hard and fast working bunch of folk.
Maybe you guys should throw together a book that explains how a company should treat it's customers.
LMS, FTW! You guys rock!
SHOForumSponsor
Thanks for the kind words and we are glad we could help you get everything all taken care of as fast as possible! We appreciate your continuing support!
Spyke
I'll second that.
Also regarding the tune seems like the shifts are a bit smoother, not sure exactly what winter related issues to be looking for as nothing seemed too bad on the previous tune other than the occasional odd choice of shifts causing hops at slower speeds in traffic. This is all using 93 soft tune btw
Do you have the trans overfilled by a half pint or so? That might help with the hops at slower speeds. Aside from lowered shift pressures, proper tire setup for road conditions, etc.
Spyke
Honestly I haven't even messed with her yet as I've only got about 6k miles on her so far. So tires are the stock Michelin primacy all seasons and trans is factory filled. So I'd chalk it up to that combined with the rather cold weather we've been having this winter.
SHOForumSponsor
I'll second that.
Thanks and glad you are enjoying the tune!
