catch can
Magna
Does the 17 sho have some type of oil seperator? If not I'm thinking its best I add one and cannot figure out which is best. Ive done a search here and nothing comes up for me sorry.
SHOinVa
Tidewater Va
No idea if the 17 has a factory installed separator, I asked that question last year an never got an answer form anyone. Its still on my to do list and since no one seems to have an opinion I'm going with the JLT version. Its half as much as the others an much easier to install, if you get a better answer let us all know.
C/
VanillaBoost
Rochester, NY
ChinoSHO15
Miami
On my 15’ SHO non pp, I installed the JLT catch can no even a month after I purchased the car and every oil change that also I use Amsoil 5w-30 Signature series every 15K I can see this things really work collecting oil. Is worth it all the way :boink:
clmnmtthw
C/
Let me know how well it works install wise
SHOinVa
Tidewater Va
I'm still not sure which one I'm going to use or when I'll get to it BUT I will keep you posted. For me ease of installing it is actually a bigger issue or as big as price.
C/
Wsho
Sacramento California
I ordered one but not yet installed supposed to be a direct fit but have to do some cutting and shortening with the hose it was too long on both of the hoses one by 7" one by 1" and a hose is so thick that you cannot bend it. First picture shows the length of the hose how I think it should go the second picture shows the connector is right up against the high pressure fuel line. The third picture shows how they told me the hose wraps down and around but it still leans up against the high pressure fuel line
Wsho
What I did today was installed up-heads display (HUD) unit. Been working on this for a week everything was built and installed today 90% complete. To break it down i formed and made a box and dome, cut a hole in the top of the dash which is pretty simple whole was already there for the Collision system which my car does not have, wired in from the OBD plug on the bottom of the dash through to the top of the dash. Let me know what you think.
Majestic
Nice work!
clmnmtthw
Mine just arrived today, want to get on over the weekend
Wsho
Wow you have a different setup than I do mine is literally four fingers apart from the left side connector yours is 5 inches away look at picture 1. And my right side connector is totally different than yours I can't even get the plug in the fuel connector is in the way mind is connected to the top yours is connected on the side see picture 2
clmnmtthw
What year is yours? Mine's 2015.
thatSHOguy101
